Seiko 5 How Many Jewels ?
Making tools is always fun. With a lath we have to put our thinking caps on for us to overcome problems.
I think you have to be mad if you think we are the only ones in this ever increasing universe. When you think of how old the universe is and compare it to how young Earth is. Aliens as you call them are probably millions of years technically advanced then us. Do I believe the U S A are hiding information from us. The quick answer is yes. I follow Steven Macon Greer if you have never heard of him look him up.
Hi All, Does anyone know if the Bergeon cannon pinion tightening tool (pusher and stump combo) #31001 will fit the Chinese Horia jeweling press clones? I can’t find the dimensions of the Bergeon pieces. Has anyone used this combination? It seems to be a more versatile solution for cannon pinion tightening than investing in the Bergeon 4733 pliers and cheaper too - if the combination is possible. Maybe someone knows? Thank you!
@Canthus - I’m trying to make your nifty nail clipper cannon pinion tightening tool but can’t find a drill bit which will get through the clipper for the setting screw hole. If you’re still monitoring this thread, can you please tell me what bit you used to get through the hard and slippery clipper steel? I have a drill press, just need the right bit. Many thanks! John
