D. I. Y. Watch Timing Machine.
By ScrewDropper · Posted
That was the conclusion I came to when I saw the marque. The thing is, what caliber? I’m going to need a centre wheel at least and I can’t find a match, although the fact it has been narrowed down to a GP is making life a lot easier -
By KarlvonKoln · Posted
Yep, I think @Neverenoughwatches nailed it. Girard Perregaux & Cie [...and company]. One of my favorite makers. Constantin Girard and Marie Perregaux were a husband and wife team! Because I work alongside my wife at my day job, and have for many years, I understand the attraction and admire them. -
You do realise that the +ve contact is supposed to press against the side of the battery and not sit on top of it. The battery should be a 319 not 379 so 2.7mm thick not 2.1mm thick which is why the contact isn't sitting correctly.
Hi @nevenbekriev, thanks for having such a close look. But it's actually all how it's supposed to be. It may be an optical illusion. These a 2/3 circle brass bushing on the lever itself and a full jewel on the plate below. The pic from the manual will clarify:
Hi @nevenbekriev, I'm thinking of replacing the whole platform. Mine is marked 4-82. The seller has 4-69, 4-71 and 4-72. Will any of them fit my clock? The white powder was not visible at first. It only appeared after I did a preclean in 95% denatured alcohol.
