Hello,
Could I please get some advise on the preferred technique for reducing the post height on an hour hand?
The aftermarket hands I sourced have posts which are too tall. The one on the minute hand is manageable but the one the hour had is too tall preventing the minute hand to completely go in (so its almost touching the crystal).
No seconds hand on the movement.
56 minutes ago, k3l3k said:
Hello,
The hour hand tube can be filed or shaved down to size with a flat lap. You can pin the hand down for filing onto pithwood or other suitable material.
Thanks, Do I need to protect the post's cavity? I worry crimping the cavity while filing it down.
Edited by k3l3k
  My thoughts would be a tooth pick fitted tight into a staking block, paper pushed over the top, the hour hand fitted over and the toothpick cut down flush with tube then file both the hour hand and the toothpick stump.
Thanks, do not understand "paper pushed over the top" part.
I'm not sure, but I imagine that you simply thread the paper onto the toothpick so that it rests against the block. Then thread the hand (back side up) onto the toothpick so that it rests against and is protected by the paper. I don't know if this is an established method but it sounds like it's worth a try. I don't know if my description is understandable or correct but if not so, please correct me!
What is a "flat lap"?
Yep H that is exactly it, to protect the finish of the of the hand while it is face down on a steel block. You could stick a toothpick in a piece of wood instead of the stake block but personally i would still thread a piece of paper over the end . By flat lap i mean the flat diamaond plates , i keep using the names interchangeably but the two are different.
I've not had to reduce the height of an hour hand tube before , but I've used similar ideas for doing other things
Clamping the hour hand by the arm seems like a good way of breaking off the head when filing.  A more simple way would be to shave the tube down on a stone or plate by rubbing it with your finger, might not get it straight though. I think you should post a picture first before trying anything.
Yes, I also did not understand "flat lap".
Also, what is the best file to use for this type of work?
Lapping plates are precision ground metal, glass and even timber disks or plates, abrasive compounds are added to impregnate and charge up the lap ready for flat lapping and polishing metal parts.  Diamond plates are sometimes called lapping plates hence my mention of the term.  Any quality small fine file should be ok, something like this from cousins.
OK.  I have these. Thanks
👍 just take your time and use the finest file you have , the tube will be very thin , the timber toothpick inside it will help to give it stability. Just a snug fit so as not to split the tube, watchmaking is about just the right size. Making yourself a micro diamond file from a diamond plate is well worth the effort.
Edited by Neverenoughwatches
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
