Down the rabbit hole!
Hi all
Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off.
A few pics to start off with
First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄
I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday.
I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good.
Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques.
And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service!
It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point.
The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on...
So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.
I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed.
Thanks for looking, Nick
Hey, Nick! Thanks for sharing your beginning attempts in watch repair and welcome to WRT. I am familiar with the Citizen and the Sekonda. Likely the Citizen houses a Citizen cal. 8200A and the Sekonda a Poljot 2614.2H. I have serviced several of both and made a service walkthrough of the Citizen which you find if you click here. There's a lovely story about the Poljot movement on TimeZone.com called Jessica’s Cornavin Dolphin.
Good luck!
