Smiths watch
By sub2001zero · Posted
I have this case that I got with some watch parts but I don't if it real or fake. I see that watch has the wrong screw down barrel on the case am I right or wrong. -
Cheers Mark, I for one would willingly offer to be a moderator. Other members beware, I'm out to get you. Hehe. Joking apart, we love the site and can't thank you enough. -
So, since the canon pinion heights differ, these problem won’t work?
The lack of end shake is huge, you must be lifting the balance by at least 0.5 mm. Is the upper cap jewel the correct way around? -
Same show.different vendor. $1US plus battery and polished the crystal and wiped the case. Added the spring bars and strap, which has a small cut that needs glue. This one has a hatch to change the battery and hand setting and hack crown is on the back! Rubber strap replaced with the brown leather with the cut. It's a West Germany dial.
