I've just completed a clean and re-build of this movement. The hair spring was a little messed uo but managed to get it back into reasonable shape. I adjusted the hair spring collet to get the roller directly inbetween the banking pins and facing right at the pallet fork pivot hole before assembly.
You can see the tomegrapher readings. This is the best I can get and cannot improve the beat error. These are not sophisticated movements of course but could I improve it? Note I have the timegrapher set at 44 degrees for lift angle which I beleive to be correct for this movement.
Thoughts appreciated.
Edited by Edifred
Does your watch have a fixed stud holder?  or
mobile stud carrier?  otherwise called beat adjustor arm.  no need to adjust hairspring collet for BE if your watch is a latter vesion, just move the adjustor arm.
 In old   ( fixed stud holder )  versions, smallest reshaping of hairspring coil , throws the balance complete out of beat, just a tweak and its out of beat.  Yours look fixed stud, shouldn't expect nice BE out of it.
Rgds
Edited by Nucejoe
Yah- looks like the fixed stud kind. I’ve gone a handfull of Baumgartners with both fixed and moveable studs. Jon’s posts on these are everything you need to know. I’ll second the above comments- don’t expect nice straight lines from these, timegraphs can give funny readings from pin levers and they were cheap to begin with. You’re close to 2ms which many find acceptable. Does it keep time? is maybe the next best question…
Yours looks to be in fine condition- pivot holes look round and these respond well to modern oils- I don’t think they saw much lubrication when they were new…
If you’re using this as an experiment to test your skills- as I recall there’s no impulse jewel but can you adjust the metal roller thingie to reduce the beat error? I never tried it…Jon also shows how you can put a tiny bit of oil on the face of it to improve things a bit.
    • You need to be more careful modifying the dial area. How does the bezel/lens fit on the front?
    • Recently inherited a box of my Grandfathers watches, nothing valuable, but some cool and some unique items.  Seiko SQ, my aunt went to Hong Kong in the 80's I believe and picked one up for my Dad and Grandpa. Below are picture, I believe its a 1987 5Y22-8A08. Put a new battery in it and it fired right up! Its probably been a drawer for 20+ years. Looks like he only wore it a few times.   Citizen Quartz 46-9181 with a seven jewel 7961B movement. It had what looked like some moisture damage, and a corroded battery. Swapped it with a 371 but it would only vibrate the second hand. Tried trouble shooting while in the case but eventually ended up pulling the movement out and cleaning with some naphtha and blowing it out and running it on the demagnetizer for a while to free up the movement before cleaning the band and case lightly oiling and reassembling everything. Now its back up and running. Based on the adjustment of the band I believe my Grandmother actually wore this watch, and I made the mistake of telling my wife that. Now its her watch! The most interesting so far is a 72-73 Benrus.  I tried putting a battery in it, but no joy. Ran it on my little tester, no signal from the coil, tried to spin it up. Just the slightest flicker of the second hand. Put some naphtha where I could reach, and tried again to spin it up. Nope. This watch is interesting in that it does not look like the back comes off, there is a window you unscrew to access the battery, a huge SR44. Ordered a crystal puller and will begin disassembly next week.  I was able to find a little bit about this watch though a google image search; BENRUS H010 TECHNIQUARTZ 1972 1st US made Quartz made by Benrus. Using a custom E-block with the step Motor, a power switch and a Moto Chip driven by MotoQ at 32KHz, on modified ETA mechanical movement. https://www.crazywatches.pl/benrus-h010-techniquartz-1972
    • It’s done and the movement feats/aligns perfectly in the case. I stripped off 10mm wide sandpaper and wrapped /sticked it around the pad with double sided tape. I run with 400 grit and finished with 1000 grit. Now I can continue with my build, I’m going to buy a dial and hands. The dial I am considering is a larger diameter 36.5mm than the allotted space 35mm in the case, so I will apply the same ‘technique’ with sandpaper and Dremel/drill. Thank you @RichardHarris123, @AndyGSi and watchrepairtalk community for your help.
    • As you're in the UK I suggest you look at Cousins for screwdriver sets as they've never cause me any problems. The key is the right blade, dressed correctly to suit the screw. https://www.cousinsuk.com/product/cousins-swiss-style-sets-rotating-stands https://www.cousinsuk.com/product/value-screwdriver-sets-wooden-cases https://www.cousinsuk.com/product/cousins-swiss-style-flat-stainless-steel
    • It's difficult to tell because of the dial ring but I expect it's the highest hand version they do know as a 'H6' The only way to be sure is to remove the hands and dial and measure the cannon pinion.
