Although I was trying to be good and not purchase anything till I had sorted out the multitude of watches I have in the queue, I saw this Accutron on the bay and bought it for £32.49 plus about $5 postage to my sons place in LA.
I had not got an Accutron 2210 up to this point in time, and to be honest the movement does not have a particularly good rep for reliability.  However, the parts are comparitively cheap compared to the 214 and 218 and through a quirk of fate I have quite a few NOS 2210 parts that were amongst a job lot of 214 and 218 bits I bought some time ago.
It is a 1973 movement and coincidentally that is when these were first produced and the movement is quite small, being used in lots of ladies watches which do not command the same prices as the mens accutrons - good for getting parts.  I queried with the vendor the size and was advised it is 34mm excluding the crown so it is in a mans case.
Condition was described as "Awesome" but I will settle for reasonably good seeing it is over 40 years old, there are some scratches on the glass and I deduce from the back that the case is gold plated which is difficult to tell from the photos, but I will take what comes.
It will be a while until it is sent over to me along with some 218 coils I took a punt on but I look forward to seeing it.
Was not going to buy any more repair jobs but I weakened, however, I am definitely back on the wagon for a while.
Cheers,
Vic
There needs to be a twelve step program for Ebay addiction.
"Hello, I'm Dave and I have a watch problem"
David S - who has enough watches to fix to keep him busy until the end of time
Got the watch and the condition is indeed good. It's a nice steel case.
Took out the battery and it is dead so I have sent off for a couple of Renatas. I have a compatible one but it is off one of those sheets of batteries you get for a pound and I resisted the urge to try it out. Hopefully in a couple of days time the new ones will be here and who knows.
Cheers,
Vic
That's a nice looking piece you've got their Vic. Fingers crossed that it doesn't need anything changed in the engine room.
And some you win !
The engine room is fully functional George with a new battery inserted and would you believe the pointers are moving as well.
There is a slight blemish to the left of the tuning fork insignia but I have decided to leave it alone for now and just check the accuracy is ok. The Vendor has put a new brown seiko calfskin strap on it which, though not quite right for the SS watch will also do for now.
So I have a fully functional Accutron 2210 - total cost £38.00 which will do for me - question is - will I ever sell it on (wife laughs in the background) - OK probably not.
Cheers,
Vic
Just an addendum.  On the original photo above it looks like there are black dots on the pointers, in fact there are no black dots anywhere, it must have been mucky when they took the photo - bonus.
Could one of the inimitable moderators put an "i" in pointers above - a small thing I know but it irritates me :cool:
Cheers,
Vic
Done!
If your like me, probably not.
No comment! :D
Just a small sample...notice the repetition....
Cheers,
Blb
    • Since I've learned lots here I thought I'd share a tip I picked up elsewhere and put to the test... For that 6105/6309 bezel lume pip look I've punched a clear plastic bottle of water, sanded it for the frost effect, removed the (smaller) pip from a standard/cheap replacement bezel, drilled it out to 2.5mm and fitted it using a smaller punch - fresh lume to hold into place.  Pressing into place is a bit awkward but you soon get the hang of it, and the end result is pretty decent I'd say... The worst part probably being the drilling rather than the pip!      It started out like this:
    • Ive asked this at a Seiko forum but I know there's plenty of experience here too...   As I have it the recently discovered servicing technique on these is that you stuff the crown full of gaskets and work it until the recessed washer pops, remove the washer, switch the gasket out, dish the washer and push it back into place, levelling out the washer in the process? First attempt did not go to plan... I tried using a plastic pusher to manipulate the gaskets in the crown... Wasn't strong enough and I was struggling to even get the gaskets in up until it broke.   Rethink consists of making/using actual tools: I don't have a staking set, so I've got the old man fashioning a metal pusher, essentially a 2.45mm OD tube with 1.6mm ID with a 6mm press the other end. Also got him on a dishing block/conical stake (sorry I'm terrible with terms) and a holder for the crown while I'm working on it...   I figure that's enough to do the process described above? Push with the metal pusher, dish the washer with the conical stake, press back in with wider flat press (drilled centre so it doesn't catch on the tap).    Plan is to stuff, press by hand and repeat? If that doesn't work by hand I've a drill press I could attach the pusher to for a little more leverage if needed. (Obviously I don't want to go too mad with that, and hopefully can avoid it altogether...)   Sounds like a plan? I'd welcome any advice here, since I really don't want to wreck a crown. Having replaced all the other seals though id really like to sort these too. I welcome any input/advice from those who have been there and done it... Thanks!
    • Hello and welcome to the forum.  Enjoy
    • You need to be more careful modifying the dial area. How does the bezel/lens fit on the front?
    • Recently inherited a box of my Grandfathers watches, nothing valuable, but some cool and some unique items.  Seiko SQ, my aunt went to Hong Kong in the 80's I believe and picked one up for my Dad and Grandpa. Below are picture, I believe its a 1987 5Y22-8A08. Put a new battery in it and it fired right up! Its probably been a drawer for 20+ years. Looks like he only wore it a few times.   Citizen Quartz 46-9181 with a seven jewel 7961B movement. It had what looked like some moisture damage, and a corroded battery. Swapped it with a 371 but it would only vibrate the second hand. Tried trouble shooting while in the case but eventually ended up pulling the movement out and cleaning with some naphtha and blowing it out and running it on the demagnetizer for a while to free up the movement before cleaning the band and case lightly oiling and reassembling everything. Now its back up and running. Based on the adjustment of the band I believe my Grandmother actually wore this watch, and I made the mistake of telling my wife that. Now its her watch! The most interesting so far is a 72-73 Benrus.  I tried putting a battery in it, but no joy. Ran it on my little tester, no signal from the coil, tried to spin it up. Just the slightest flicker of the second hand. Put some naphtha where I could reach, and tried again to spin it up. Nope. This watch is interesting in that it does not look like the back comes off, there is a window you unscrew to access the battery, a huge SR44. Ordered a crystal puller and will begin disassembly next week.  I was able to find a little bit about this watch though a google image search; BENRUS H010 TECHNIQUARTZ 1972 1st US made Quartz made by Benrus. Using a custom E-block with the step Motor, a power switch and a Moto Chip driven by MotoQ at 32KHz, on modified ETA mechanical movement. https://www.crazywatches.pl/benrus-h010-techniquartz-1972
