God evening! Long time since posting, but had to finish up school...again. Now I have time to overhaul my Omega beginning with the Dubois chronograph module. My problem is the reset pusher has a broken coil on the pusher spring so its a bit short. After cleaning, greasing with a little molykote, the pusher hesitates to spring back into position when pressed. Where can I get a new spring. Thanks for any suggestions.
Joe
Try to get the case pusher spring part number from the Boley website. Then you can search material sources such as Cousin's UK and search using the spring number. I did this for a Seiko chrono pusher spring.
Edited by Razz
Thanks Razz. I have access to the Matsys best-fit database, but not Boley. I did find some replacement springs on Cousins UK, but not sure of the dimensions I need.  I will have to do more research but thank you for the jump start.
J
With the pusher spring it is the case part and with the Seiko they have a case number as the movements usually fit a number of cases so the movement number is of little help. You could measure the other pusher spring to get the dimensions unless it is a mono pusher...
The case reference is Omega Reduced Speedmaster 175.0032, the same as 175.0054 175.0084. I foundthe pusher on Cousins UK: Omega 086ST0079 Pusher
If only I could find just the spring. They only sell the entire pusher. I live in the U.S. so maybe theonline auction site is the way to go....First World Problems!
Joe
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
