A goal acheived
I joined this forum about a year ago after getting interested in watches from digging out 3 inherited watches; 2 pockets and the Omega pie pan that is my avatar. My goal was to get proficient enough to work on my ancestor's time pieces. What I did not expect was how deep I would become immersed and what a great community of sharing ideas, learning, historiy and stories I would find here. I previously spent time in a coin collecting forum but the depth of horology intrigues me much more than numismatics, although that is a great hobby /profession as well.
I find myself fairly emotional as I write this post as I just managed to get the worse of the 3 watches running! It is a Swiss pocket watch with a clam shell silver (0.800) hunter case all matching serial numbers. The inscription is to my great grandfather from his father and dated Jan. 9, (18) 91. Yes, 133 years and 6 days from the presentation. There is a ways to go for restoration, but my grandfather passed more than 47 years ago and it is ticking again...20240115_2014002.thumb.jpg.c1f2fa3cc73d30dcc589dc1492ef16c3.jpgDSCN56952.thumb.JPG.98be11a3a3fe4aba729de23769d4acde.JPGDSCN56942.thumb.JPG.3ce2099af25a19aac9d15384f19fb625.JPGDSCN56932.thumb.JPG.fb188f01447e0c394cf8ba453d053b15.JPGDSCN56982.thumb.JPG.07250cd63f674265bc6bc2ed9a02eb8b.JPGDSCN56962.thumb.JPG.7c7e8dbef5f4163bc62ccf21418b4df6.JPGDSCN56992.thumb.JPG.8f3617716626c739fc6f841035a2eced.JPG
I am hoping folks here can help me try to figure out the watchmaker who made this. This last shot is cool in that you can see the paper under the train bridge in front of both screws.
The biggest clues I see are the Locle and L or LE Robert engraving on the movement cover plate. This is different than the presentation engraving and is not the name of my relative. Several houses got their start in Locle Switzerland including VC, Ulysses Nardin, and Zenirh I beleive. Thanks for reading.
  • Like 5
😅 yes it gets you like that , i was still filling up an hour after i got my grandfather's watch ticking 50 years after he died. Funny hobby this , for another the next day you can end up vocalising loudy multiples of expletives joined in a variety of unimaginable ways.
I put some information into an AI program and it spit out L. Robert Le Locle, brand of pocket watches started by Louis Robert in Le Locle in 1869 and later the company was sold to Jules Mathey in 1929. Not sure how much of this is true because you have to fact check AI. The watch movement is 28.6mm or about 12 1/2 ligne. It is a crown wind and crown hand set as well (by pressing a button on the edge of the case and turning the crown).
    • Personally I would just replace like for like.Or just polish the old crystal and refit.
    • I've also heard it called the "top side" and the dial side the "bottom side", which should make any non-repairer very confused. There are many examples and sometimes it comes down to personal preference. Personally, I like to say "dial train" whereas most other people would use the term "motion works".
    • Is magnetism such a major problem that we (as home hobbyists) need to spend $$$ on a fancy demagnetiser? I use one of the cheap blue Chinese demagnetisers (£10 from ebay). It works, and has never failed to demagnetise a movement, or my screwdrivers. Magnetometer - who needs one?  Take a very small screw. If it sticks to the clean part, it is magnetised 🤣
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
