What a struggle.
Hello all
Rebuilding my Cortebert 720, what a struggle.  Half an hour to get the arbor into the mainspring, the same with the bridge for the escape and forth wheel bridge.  The click spring was bent, when screwed down it popped up at the click end. Carefully straighten it.  About 3 hours to get so far.
Hello all
Keep going you'll get there, I've had ones where its been backwards and forwards for months. Soak up that learning experience no matter how long it takes.
It gets easier with practice, keep going 😀
This afternoon I has the same problem as you - I fitted a mainspring where the inner coil was much smaller than the arbor. You can either take the spring out, and open the inner coil slightly with some round nose pliers, or do what I did. Put the arbor over the inner coil and press down lightly with some tweezers. Then I used an old sharpened oiler. Push it vertically down in to the end of the spring, to force it out a bit so it goes round the arbor, then slide the oiler back around the coil, opening it as you go, and in pops the arbor !
We feel your pain 🥰
I struggled with arbors the same way, until…🧐 So for when the going gets tough or if you just want to try a different technique- instead of the anvil or the bench or whatever to rest the barrel upon, use one of those pithwood buttons, a big one, flat with a good hole in the center. It grips the barrel sufficiently so you can use the arbor to gently open the spring. Arbor hook in the spring gap, light pressure with the tweezers and turn the whole kit (not the arbor) opposite the spring direction so it opens up the coil and accepts the arbor…and if it doesn’t work, the button’s grip on the barrel will allow you a free hand to manipulate the spring a bit with a tool to coax the arbor in.
Makes quick work of it every time or your money back…😳
    • Update, I discovered that I could change the mainspring by removing the arbor and sliding it out from between the front and back plates. So I put a new mainspring in. This it what I  get over a 7 day period After winding                                          amplitude is 1 1/2 turns plus a few degrees.        ie just over 1 1/2 turns. 1 day after winding     gained 1 sec      no amplitude check. 2 days after winding   gained 1 sec      amplitude 1 1/2 turns        i.e. it lost the few extra degrees 3 days afer winding    gained 3 sec     no amplitude check 4 days after winding   gained 5 sec     amplitude 1 1/2 turns        i.e. unchanged 5 days after winding   gained 7 sec     no amplitude check 6 days after winding   gained 16sec    amplitude just over 1 1/4 turns 7 days after winding   gained 24sec   amplitude 1 1/4 turns. From  Based on video inspection, I am getting full pallet lock. So, my data seems to be at odds with the statement "swing of a balance wheel has nothing to do with the rate". However, I have noticed the banking posts are not controlling the lever position on the right side.  I may have some work to do here.
    • I can't tell whether or not some stem is stuck in the crown, I  think so though.  If the crown is stainless steel you could try alum to disolve the stem of try drilling it out. If all else fails, buy a new crown.
    • Does anyone use the x5 eyepieces,  when i use them on my different amscope , the magnification changes to x5 but the field of view remains exactly the same as the x10, so nothing gained. The optical lenses can't be swapped out or at least they are not available as far as i know.
    • I think maybe we're all a bit dim @ManSkirtBrew 🤣 99% of the time I'm working with the 0.5X Barlow, so mags from 3.5X to 22.5X. When I need a close up of a pivot or jewel, I take the Barlow out, and even put in the 2X Barlow, but it's a nuisance. So like you, I had that D'oh moment, why don't I just use 20X eyepieces (WF20X/10). They take seconds to change, and you keep the working distance. The only downsides are lower field of view, and less brightness.
    • At the lowest magnification, I can just get all of a normal wristwatch size movement in field. For some things it's too much magnification, but the nice thing about the eyepieces is they only take seconds to swap in and out. I'm genuinely surprised I've never read about anyone else doing it, to be honest.
