Case needed a lapping machine....So I improvised - Results are amateur but promising
I decided to do a little improvisation last night. I had a case where the sides were extremely worn, dented, etc. The case lines were nearly worn completely down.
I've wanted a lapping machine for some time but those are far too expensive for my humble budget. I improvised by hooking up one of my sanders to a voltage regulator to bring the speed down as much as I could. I put some 1000 grit paper on the disc and started to gently work the side of the case. I'm quite surprised at what I was able to accomplish with these rag-tag tools and bit of creativity. I'm limited by the table because it can only adjust to 45 degrees, so there are some angles on that case I won't be able to reach properly. While looking up pictures on the internet of other examples of this case it looks like there was not a sharp line between the side wall and the lugs, so I just tried to bring back a gentle curve between those to sides. Not too bad for my first attempt! I'm going to keep moving forward and go up to 2500 grit and see what I can get out of this before moving on to the polishing wheel.
Edited by thor447
  • Like 5
1 hour ago, watchweasol said:
Hi A tidy job. Improvisation sometimes produces remarkable out comes.   Nice one
Thanks.  I need to work on my photography, clearly!  The rebuild video came out pretty well, but I still struggle with getting a good still shot.  It's a skill that I have yet to learn.  I mainly rely on luck, which isn't reliable at all, haha!
16 minutes ago, Neverenoughwatches said:
Look great, did you re-brush the top edge or is that how it was ?
I re-brushed it.  Originally it had vertical brushing, but it was all but gone by the time I got the watch. The light reflecting off the top makes it difficult to see the brushing, but it actually looks pretty good in normal light.  As I stated earlier, I'm not a photographer by trade, haha!
I tinker with watches and occasionally upload a video to YouTube, including one for this watch.  I'm not here to promote my channel, as I've been a member here long before I began uploading content (started doing it at the request of a friend).  YouTube is just a hobby, and this is a place I can come to ask for advice, look at other's projects, and is a wealth of knowledge (on top of Mark's courses which I thoroughly enjoyed).  I did not want to sour that by trying to promote a YouTube channel here.  If you'd like I can send you a message with a link to the video.  I recorded the entire process of using the disc sander and brushing the case.  It isn't perfect by any means, but I think it turned out pretty well with the tools I had on hand.
Edited by thor447
    • Ah so its you thats buying up all the DD calibres 🤨.
    • Hi Richard,  I keep buying CAL.59 movements to practice on 🙂 Not started yet though, I'm gathering tools and building my confidence to start.
    • Problem solved. For some bizarre reason, the hook on the wall of this barrel is not properly centered vertically, but is oddly high on the wall, maybe 3/4 up the way up. When replacing the mainspring, this caused the outer coil to be displaced upwards as well such that it protrudes out of the barrel and caused the barrel lid to not sit quite flush to the barrel. Since this is a motor barrel, the lid is actually the first wheel and inner coil tube/hook all in one piece, with no “snap down” action that would have made the problem more immediately obvious. Maybe with an older mainspring the spring’s end hole was enlarged such that this wasn’t an issue, but hard to say how it ever worked otherwise. Replacing the barrel with one from a different model 1900 where the hook was properly vertically centered allowed the lid to sit flush without mainspring interference and the friction problem went away. The bridge was far too thick to be bent (and isn’t), for those of you thinking that was the problem. Placing the removable arbor in the watch without the rest of the barrel proved that the proper end shake was actually there as long as the overall height of the assembled barrel was correct.
    • You are so true on a lot of what you have said. The main reason for changing the mainspring even if the old one is in good order is because it will take out your thinking that the mainspring is contributing to poor power output or fluctuations in amplitude. If a new spring is fitted that box can be crossed off as a potential source of a problem. Most customers are happy to pay the extra £20 for a new mainspring if they are already parting with a couple of hundred pounds for a service. A new spring is an investment for good running for the future.
    • According to Borel the 814 and 815 use the same escape wheel. It's kind of an oddball being so long.
