Greetings to everyone,
Recently there was this nice watchmaker festival, and while looking around I stumbled upon this nice little mainspring winding set. The price was right so, I couldn't resist from not buying it.
On the box and on each tool says Bergeon, and the kit looks like it was never used, some parts even covered grease. Googling did not bring much results, if any at all.
So I'm just wondering, is this a real deal Bergeon winding set, or a modern reproduction of some sort?  Does anyone know?
Thank you!
It's 100% Bergeon. Well.... Bergeon had it made. I've owned probably a dozen sets of these, some marked Bergeon, some no name, but clearly from mid 20th century. Identical. There are little nuances, also between Bergeon sets of the same period. Definitely Swiss in any case.
The big change on these was when they started making "Nivaflex" sets. The only real difference is instead of a hoky (usually too long) hook, the hook is "internal" to the arbor. Basically machined in, on a spiral, like a real barrel arbor, instead of being whacked in raising metal with a punch. I think it was to accommodate some of the unforgivingness of modern alloy springs being stretched out. Caliber specific winders soon followed, as the trend became to make barrel arbors smaller to allow more spring length, and the old standard winder arbor diameters proved to be too large.
I might have this identical set- will check tomorrow when in the shop. I like that a lot of folks back then wrote the date purchased under the lid, I think the set I use most is marked 1943 😮.
3 hours ago, swiss2k said:
Wow. So it's more of a museum piece than an actual tool?
If all the vintage tools that watchmakers are currently using were to disappear because it's a museum piece watch repair would cease to exist. Vintage means nothing to a watchmaker that is a very usable tool.
That's my main set, was off on the date a few years. And another set with the same info sheet as OP, I think the quote in German is something like, "if you want good health, don't take pleasure in good things", maybe someone is more fluent here?
Pretty much correct, according to my German friend.
Who wants good health, should enjoy good things not to much. 😃
Funny. Tell that to the guys with APs, Rolexs and so on... just kidding)))
Cool sets btw! Thank you for sharing.
Understood. Thank you
Seeing as how most of my tools for jeweling and staking were purchased from antiques dealers this is wise…
    • Hello and welcome to the forum.  Enjoy
    • You need to be more careful modifying the dial area. How does the bezel/lens fit on the front?
    • Recently inherited a box of my Grandfathers watches, nothing valuable, but some cool and some unique items.  Seiko SQ, my aunt went to Hong Kong in the 80's I believe and picked one up for my Dad and Grandpa. Below are picture, I believe its a 1987 5Y22-8A08. Put a new battery in it and it fired right up! Its probably been a drawer for 20+ years. Looks like he only wore it a few times.   Citizen Quartz 46-9181 with a seven jewel 7961B movement. It had what looked like some moisture damage, and a corroded battery. Swapped it with a 371 but it would only vibrate the second hand. Tried trouble shooting while in the case but eventually ended up pulling the movement out and cleaning with some naphtha and blowing it out and running it on the demagnetizer for a while to free up the movement before cleaning the band and case lightly oiling and reassembling everything. Now its back up and running. Based on the adjustment of the band I believe my Grandmother actually wore this watch, and I made the mistake of telling my wife that. Now its her watch! The most interesting so far is a 72-73 Benrus.  I tried putting a battery in it, but no joy. Ran it on my little tester, no signal from the coil, tried to spin it up. Just the slightest flicker of the second hand. Put some naphtha where I could reach, and tried again to spin it up. Nope. This watch is interesting in that it does not look like the back comes off, there is a window you unscrew to access the battery, a huge SR44. Ordered a crystal puller and will begin disassembly next week.  I was able to find a little bit about this watch though a google image search; BENRUS H010 TECHNIQUARTZ 1972 1st US made Quartz made by Benrus. Using a custom E-block with the step Motor, a power switch and a Moto Chip driven by MotoQ at 32KHz, on modified ETA mechanical movement. https://www.crazywatches.pl/benrus-h010-techniquartz-1972
    • It’s done and the movement feats/aligns perfectly in the case. I stripped off 10mm wide sandpaper and wrapped /sticked it around the pad with double sided tape. I run with 400 grit and finished with 1000 grit. Now I can continue with my build, I’m going to buy a dial and hands. The dial I am considering is a larger diameter 36.5mm than the allotted space 35mm in the case, so I will apply the same ‘technique’ with sandpaper and Dremel/drill. Thank you @RichardHarris123, @AndyGSi and watchrepairtalk community for your help.
    • As you're in the UK I suggest you look at Cousins for screwdriver sets as they've never cause me any problems. The key is the right blade, dressed correctly to suit the screw. https://www.cousinsuk.com/product/cousins-swiss-style-sets-rotating-stands https://www.cousinsuk.com/product/value-screwdriver-sets-wooden-cases https://www.cousinsuk.com/product/cousins-swiss-style-flat-stainless-steel
