Good evening,
I was "picking" in middle washington state and came across this photo which reads 1923 Class Society Bowman Horological School.  I googled the name and found a Bowman Technical School in Lancaster, PA, which specialized in watchmaking; but nothing with that exact name.  Does anyone know anything about this school?
I find it fascinating to look at the faces of these would be watchmakers.  What's their stories.  Not to mention its quite comical to look at some of those hairdo's.
thanks for posting that John.  Attached are two class photos of the bowman technical school; from the video you posted.  it's funny to see the difference between the two classes.  all ties on the one hand, tank tops and shorts on the other.  i'm guessing this is not the same school as the picture i posted only because i don't see where the Technical school refers to itself as the Horological school.  Interesting nonetheless.
    • Hi Joe, I mean the situation when the escapement can be unlocked when pallet fork is pressed as the guard pin to touch the guard roller. This will be possible if the guard pin is short or the depthing of the escapement is not deep enough. The pallet fork was replaced, but I don't think it was adjusted to work correctly with this movement.  Of course, if there is defect on the guard roller, it also can lead to such problem.
    • Hi everyone, I am new to watch repair and loving the whole process, even some of my fails…maybe. Right now I am looking at purchasing a press for fitting watch crystals, and I was wondering if any of you have had experience with the BMC model (seen in photo) and if you know whether the Robur press dies would fit, or, if not, what alternative dies might as I am having trouble sourcing original ones.   I know that the subject of crystal presses has been a well covered topic here, so I apologies for bringing it up again but I hadn’t found any past threads on this points. Any help on this would extremely helpful. Thanks! Joshua
    • Hi, I just wanted to share the unmistakable quality of a Rolex made in approx. 1990. Cleaned and serviced for a friend using appropriate oils and greases, with Epilame on the parts recommended by Rolex. New mainspring and upper setting and jewel for the minute Pinion (cracked jewel). Run in overnight and then worn on the wrist for a couple of hours to warm. Without any adjustment to the balance weights the watch ran at 0 SPD DU, all positions within +3 and -2. Vertical amplitude after 24 hours of 230 degrees minimum. Watch running at zero seconds per day on wrist when worn 24 hours. Serviced just once before 20 years ago. No need to buy the Microstella regulator tool, not this time anyway 🙂 No scratches or damage caused to screw heads and bridges. All seals replaced and waterproof tested to 60 metres. All good practice for when the time comes to service my own Grand Seiko.
    • My kid woke me up at 2:00 a.m. I couldn't get back to sleep so I decided to go to the workbench. I was to tired to work on a watch so I decided to dress up tweezers and screwdrivers while having a drink and listening to some music.     Luckily I got a comforting nap after lunch and started working on this beautiful Raketa Big Zero.
    • Good shout - I'll grab something like that and some around the required size from cousins too...
