I serviced a ball watch using an eta 2824-2 movement. When I put back together the assembly where all the winding, date set and time set is, the lever doesn't slide the one pinion back all the way to wind the watch. Also the rotor rubs the screw that hold the balance assembly. Ugh!!
The set lever has jumped out of its groove...either slipped out when you put in the stem or incorrectly assembled in the first place.
I've heard that if you assemble it and then put it in hand-setting position before you remove the stem helps on reassembly.
For the balance clock screw you be probably got the wrong screw in there... unscrew the other screws to find the correct one.
Anil
I'm with Steven on the winding/ setting... The spring needs tension on it to work..
As for as the rotor rubbing the balance screw .....I'm thinking you may have the wrong screw in it?? ( balance).
Let us know when you figure it out.. Interesting !
It was a wrong screw in the balance. I always keep the screws with there part and somehow got it mixed up. Anyway the screw was longer and it was going all the way through and jamming the lever set assembly. Everything perfect now. Thx for all the replies.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
