I'm looking for some guidance on beginning the repair process on my Elliot 7 day bulkhead clock, which routinely stops running after a few days. It doesn't seem to stop at any particular time. Any ideas please. Cardiff UK
Hi. Intermittent stopping is indicative of the clock requiring a service ( dismantle clean and oil).  Possible causes are many the common one being dirt, congealed oil, worn pivots an bearings , also a broken main spring etc.  All of which requires the clock to be dismantled and inspected. A picture of the clock and movement would be useful.
A watchweasol has said it sounds like a good service is needed. The funny thing is I have many Elliot clocks from timepieces and Westminster chimes, one of my timepieces stopped last night. The normal duration is 8 day not 7 as you said.
Hi Watchweasal and old hippy
I think I have discovered the cause. The main cog that transfers power from the mainspring has worn the bushing and dropped.
I think this will be beyond my abilities. Suggestions please?
Thanks in advance
Having done some research and on closer inspection it does look as though this pivot point has been bushed previously; the bush itself looks as if it has worn away. Perhaps dismantling and drifting out the worn bush I might be able to rebush this myself. All comments would be welcome gentlemen.
It definitely needs re-bushing and with those punch marks around someone has tried to tighten the bush that was used, I would say the hole was broached to big for the bush. So it was a complete bodge up. The old worn bush needs tapping out and a new one fitted. In this case the hole might need to be plugged first before re-bushing. The pivot needs to be checked for wear and will certainly need to be burnished.
Thanks old hippy
Its  shame really as it was purchased from a reputable clock repairer for not an inconsiderable sum. As you say it has been botched; even I can I can see that and I'm not a clock repairer.  Plugging holes sounds quite technical; what's involved please?
I'm trying to weigh up how much of this I can do myself.  Thanks so far.
Well what do you say, if this is the work of a reputable clock repair it’s pretty poor. It is definitly needing a rebush. What Old Hippy has said holds true. The old bush out the hole tidying up and a new bush pressing in. I my self would drill the hole to remove the punch marks and make a bush to restore the plate but for that you need a lathe. Looking at the bush the condition of the pivot may also need attention, burnishing at the least to restore the surface. It’s not impossible to do it by hand , but will take care and time.
Thanks Mr W
Fortunately my brother in law has an engineering lathe; he makes model steam engines. So if I get him to drill the plate as far out as the punch marks, then perhaps it will be possible to press in a brass bush. What is the best way to measure for the correct bush please?
I've noticed that several of the spindles carrying their brass cogs are made of steel. Have they been replaced or was the movement originally manufactured this way?
I'm beginning to wonder if this might be a new hobby for the winter months as sailing tends to occupy me during the summer. Would you recommend any up to date text books to start me off?
I really appreciate your help with this...it's fascinating!
Hi that would be good to restore the plate (no marks).    The pinions are traditionally steel and the wheels brass . Brass being softer rind smoother with the steel ,less friction.
books wise there are several though not cheap,  Clock repairing by Donald De Carle, is a good starter. Although it was written some years ago the principals are sound,  books by Laurie Pennman, Loomes, Mike Watters,  all worth a mention.  Google For books on clock repairing and you will get plenty to choose from.  If not sure on choice just ask there are plenty of members who will help.
16 hours ago, Harlequin said:
Thanks old hippy
You are going to need brass rod of just over the diameter of the hole. You will need drill the hole. If drilling you will need a drill press or a lathe with the drill press attachment which I have. You will then have to find the center of the rod before you punch mark the center. You will have to get this right or the depth will be wrong for the wheels to run correctly the teeth depth must be correct. A clock depthing tool is best for this. Don't get me wrong but this is not a job for someone who has never worked on clocks.
Hi All the above mentioned by Old Hippy will have to be done in the correct sequence,
Inspect and clean up the pivot and burnish. Now measure the pivot.
fit rod into lathe and drill the hole ( size just measured)  just under size, it can be broached, sideshake 0.1% from the vertical.
then cut / drill the plate and measure the hole for size
then take down the rod to just over size as you want it to be a friction fit, it should be a slight taper and jus fit no more than the into the newly cut bush,     The plate can also be broached by hand for a good fit.. A daunting job for a non clock repairer   Good luck.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
