Hi all
Ketil71
Hi Richard. Commonly called the postman’s clock. They were similar but had an alarm feature. Might take some time getting bits although a dose of woodworm juice wouldn’t go amiss. I have repaired two of these one sits in the workshop. Interesting old clock probably Black Forest in origin.  The bushes in the woodwork wear or come loose but will clean up ok     Good luck.
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
This looks like an Austrian Wag on the Wall. Do you have the pendulum, weights, hands and dial. Ca you post other photos as I'd like to see the other side and between the plates.
Thank you for the welcome.
Unfortunately I only have the parts shown on the picture. Pendulum, weights, bell and clock face is missing.
Would it be possible to date this?
What would be the best way to clean the combined wood/brass parts?
More pictures (in various states of dismounting)
On 8/23/2023 at 9:10 AM, oldhippy said:
Pictures tell me things and with out the other parts makes it a little difficult. I think this is German from the Black Forest. I would date this around the 1870 to 1900.
So, we found the clock face as well. 🙂 I have only seen the picture so far, but it looks like it is paintet on wood?
    • I also agree with @mikepilk and @Waggy. Your readings look good. The amplitude drop between the horizontal postion and the vertical position is nice and low (only 18° difference).  The delta of 17 sec (-3 to +14) between those positions is absolutely ok. If you really wanted to improve on this, I think you'd have to look into the poising of the balance wheel (not the spring, which looks perfect). But that's a total overkill for this kind of movement. Leave it be.
    • I've just finished refurbishing a Memostar Alarm with AS 1931 movement (same as 1945 but with date and running at 21600). I was also surprised how many parts are available at Cousins. Like you, I was missing the alarm stem (Cousins stock them) and I needed new crowns. It's a nice simple movement for an alarm, easier to service than a Seiko Bell-Matic. BTW I made a note in my Servicing spreadsheet: "Pull out winding stem before removal".  It may have just been wear on my movement, but I found that the yoke could move out of the clutch if the stem was removed in the normal position (like some ETAs).  You might find this interesting
    • I picked up this alarm watch at a flea market several months ago and recently decided to investigate.  I am not finished, but well on my way. As you can see, there was significant water damage.  Running these parts through my L&R cleaner was not enough to clean them, so I did manual cleaning with one-dip and cotton swab (the dense pointed kind).  The wig-wag was stubborn--the two gears would not release from the plate.  I soaked it in Kroil overnight and that did the trick. There was some rust on the balance staff, but not actually on the pivots themselves.  Nevertheless, I chucked it a step-chuck on my lathe and burnished the pivots. The watch is running and I have confirmed that the alarm drive train is functioning.  Since I am missing a stem for the alarm, I have not done the final assemble of the alarm components.  Surprisingly, there are lots of parts available for this movement on Cousins.  I will probably get a couple of stems and maybe some other parts that I deem necessary. The watch is running at weak amplitude (about 190) and shows some poising issues.  I will work on that. The last two pictures are after partial reassembly.
    • Hello and welcome to the forum.    Enjoy
    • Exactly!  It may not really be a joke, but the actual truth.
