Hermle 130-020 "Bim-Bam", plate separation
Moose
Hello.
I am needing to re-bush the main and strike barrel arbor pivot holes on a Hermle 130-020 (know as "Big-Bam Strike" I think).  This is one of those with a vertical, free-sprung balance wheel. But this is my first Hermle movement and I need a little bit of guidance please.
The issue I have is that I can't see how to separate the rear plate from the front plate. I have removed all of the nuts and stripped the strike hammers and escapement away, as well as the plate holding the twin barrels in place. But how to get the back plate off and get access to the gear trains for re-bushing is currently a mystery to me.
Hopefully the photos are fairly self-explanatory, but the blacked posts seem to be riveted into the back plate, so that it won't come off. It may just be that they are on extremely tightly and need to be levered off, but I don't wish to damage anything, if it is something I have missed.
I hope someone can give me a little bit of a steer on this one.
Many thanks in advance.
Edited by Moose
Spelling
10 hours ago, watchweasol said:
Hi Moose I think the last one I did the posts unscrew releasing the plate.
watchweasol is correct. These movements are not made with strong brass or hard steel so the wear a lot and the springs are to strong for the metal a bad design. You will find how soft the brass is when you re-bush its like a knife going through butter.
Edited by oldhippy
I forgot to mention. From your description it sounds like it is a floating balance. Just clean it in Ronsonol lighter fluid then dry it with your bench blower. at each end of the balance where the wire goes through it should have a jewel, a tiny drop of oil at each end then move the balance up and down a few times so as to lube the wire, I always used a pocket watch oil, but Windels clock oil is fine for the job. Always use that oil for general clock repairs its the best and it is not expensive. Here is a photo of a floating balance I'm hoping it is something like this, if not can you post a photo of it.
Thanks for everyone’s help and tips.
Got it finished today and now just running it for 7 days or so, to gauge the rate and power reserve.
No issues to speak of; the wise words of Oldhippy regarding the softness of the brass plates saved me from being over-aggressive with the reamers!
Oldhippy, I did not lubricate the balance, but after reading your tip, I will go back and do it, as the amplitude seems a little low, although it it is keeping good time.
Edited by Moose
Thanks Oldhippy. I don't have a purpose made tool, so I had to do it by hand. I have done it a few times previously, but not on such a large hole (6.5mm with a 4mm pivot hole), or on such a soft plate!
I took the balance out again and re-cleaned it and used some clock oil on the jewels/wire, as you suggested.
I was considering a grease on the escape wheel teeth/pallet pins, such as Moebius 9415 (as per watch escape wheels). What do you think, would this be too light for this escapement?
Thanks, will do that.
G.
As a matter of interest and not having worked on this type of balance before, what is an acceptable balance amplitude?
I seem to be getting around 260 degrees - or thereabouts - based on a slo-mo video capture. I would regard that as OK given the age of the thing.
All complete now and sitting for a long term test till I give it back.
Cleaned and lubricated the balance jewels and also lubricated the pallet-pins and teeth.
Now seems to be achieving around 290 degrees amplitude (by eye) and keeping time to within a minute or two over 12 hours. The extended test will give a result over 7 days and I can make further adjustments as required.
Many thanks for all the suggestions for repairing and servicing this interesting (for me) movement.
Photo during re-assembly. New bushes fitted, partial reassembly. Just prior to the barrels being refitted. Then the strike hammers and escapement on the other side.
And a before pic.
Edited by Moose
I’m sure it will be better than than that over a longer period, as that was just for the first 12 hours. I had to put in a big adjustment on the balance adjuster to get it to come into reasonable time. I suspect that it had not really been adequately serviced for years, if at all, since it was assembled. So I have not yet had time to measure the going rate over an extended period, as it arrived non-working.
I have high hopes it will settle down well.
Edited by Moose
    • Could it be an abbreviation for Denier? "Denier (/ˈdɛniər/) or den (abbreviated D), a unit of measure for the linear mass density of fibers, is the mass in grams per 9,000 metres of the fiber. The denier is based on a natural reference: a single strand of silk is approximately one denier; a 9,000-metre strand of silk weighs about one gram." The pivot gauge looks interesting, however I wouldn't trust myself to drive a pivot into a wedge incase it jams and gets damaged/snaps trying to get it free. More a comment on my ability and incompetence than the quality or design of the tool 🤣
    • As I've seen multiple posts here about multiple types of cleaning solvents, I've done little more than confuse myself more thoroughly that I was before. To see if I understand things correctly... 1.  Is One dip is a solvent which is a cleaner and also a protective rinse for hairsprings jewels and pallet stones only? Or can it be used on all the parts (like the case and wheels and all the things) It seems like that would be much easier as it's just "one dip" but it is very expensive. 2. Isopropyl alcohol is a great cleaner for manual cleaning or ultrasonic cleaning (only enclosed jar) just not on pallet fork as it may loosen the shellac holding the stones. Does it have to be 99%? 3. When buying a small manual cleaning brushes, does anybody suggest a certain material of the brush itself?
    • I am new to the new to the watch restoration hobby I have the basic tools. I'm here to learn new things. And utilize my resources (you guys) to expand my knowledge and hopefully save some derelict timepieces from the trash.
    • @Knebo It does make sense.   Most companies are trying to squeeze independents out.     Maybe I wasn't clear and complete. He said, the mid-case has been polished, he says it was probably to remove pitting. - It kind of makes sense to me, as the pitting on the caseback doesn't match the story of the mid-case. - The case is clearly overpolished and the lugs nicely brushed without any marks, so watchmakers are clearly polishing that area the question is how and how much. I am swarmed with work and will be visiting my watchmaker in a few days with the checklist and will post an update then. You have been really helpful. PS. Refer to the pictures in my latest comment for reference to this and the case at 9'o clock is actually sunk. the drawing is a bit hyperbolic.
    • @clockboy The damage on the movement much worse. The images against the green background are my watch the other 2 are from the internet. The rotor has erased the perlage. I am surprised how is this watch still running.
