Rodico and German (Nickel) Silver
My dad has a Citizen Pro master Wingman with a C720 movement in it. He took it to Timpsons for a battery replacement and the guy in the shop said he can't guarantee it will still be waterproof. Anyway it turns out it's not waterproof and now it's full of water. Would anyone know where I could find a technical sheet for this movement? I've tried looking online a bit today but can't find anything! Â Thanks in advance
You would at least need to poise through those positions before regulating. -
I have seen videos where the servicing seems of a good standard but did nothing with the case, spoiled everything. Why leave the case in such a poor condition? -
Also the lift angle is set at 52 degrees. I can't find the LA of this PUW 1563; it could be 42 degrees which would drop the Amp quite a bit as well.
Hi Rob, I am not sure if You understand the meaning of 'Adjusted to 5 positions' correctly. Just to clarify, do You believe, that if You get a cheap 'Unadjusted' movement, It will be possible to turn it to 'Adjusted to 5 positions' just by adjusting the rate regulator with the help of some kind of timegrapher? Sorry if it is my missunderstanding...
