Advice Needed
Hi,
As part of my next stage of learning I am going to work on some automatic movements I have, taking apart, studying how they work and putting them back together again. Up to now I have only worked on hand wound movements. One of the items I need to get is some braking grease to use on the inside barrel wall. I have been researching as much as I can and there appear to be two main choices - Moebius 8217 and Kluber P125. The Kluber is considerably more expensive, but if it is a good product I'm happy to pay as I imagine it will last a long time.
I'm just posting to see if anybody has a view on the subject, on these products or perhaps others not mentioned. Thanks
Stephen
    • Yes, Mine has a support for the blade that can be safely hit like this one https://www.amazon.co.uk/Rolson-62841-Tradesman-Knife/dp/B0044D9MC6/ref=sr_1_37?crid=3HWJF1HL4J8D7&dib=eyJ2IjoiMSJ9.X58oai8WcFho_-XqfR-lLQbU8lQKhf1vtFKAWbXR4EAhqVWR_eMy5h1DhaCULvkpA6XT0GaNFLHt_kJ0kPrhXFo0nYd8yJ4JgruoXDG9XjViAQOyAiBUkOhC9W9qQfGr0SMKpxIUrGOBkTjtTPTuM9IOTnb-dEAzbcZVvniVcEuMFGK9SITyDO6ryUU8ERkHt8f2Vy9Ks0QFO06KSJz65C2p7S3o2lOaUoO9kw61KyNtaaYYwdZzyuM2uRywODaigUn0u8RHMPR0dOa3WSrq8vE1iV5Et_561SFfvkhSGTQ.9QrdWVoCJpLVkrflNS1sxaY56ys4iiJspEFpUgLIRdg&dib_tag=se&keywords=stanley+knife&qid=1716289527&sprefix=stanley+knife%2Caps%2C77&sr=8-37 I use a brass hammer. You could use a very light pin hammer. A watchmaker's hammer would be a bit too light to use. I'm not sure of the weight, but looking at Cousins, it looks like a 60 or 84g brass hammer. I would go with the 84g one. A lot of the process is about feel, so you don't damage the case or bezel. Don't twist the tool! You may think it would make it easier and quicker, but that's when the damage starts to happen and be especially careful around the lugs. Once you have done a couple, you'll get a feel of it. Some bezels feel like they're not coming off and you start to doubt what you are doing. The trick is to be deliberate in your actions, rather than tentative. If you perform this task with the total belief that the bezel is coming off, that is exactly what will happen. First, be totally sure that the bezel comes off in the way you expect.   Rub the blade against a piece of 400 grit wet and dry until blunt
    • I do like the idea of clocks , you get so much more for your money than you do when buying a watch.
    • No but I have taken it out of its case to make sure all is well.
    • I read recently that there are almost 600 different patterns of overcoil.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  Gabriel clocks are my thing.
