Strange finding
I was starting a new watch and found a second hidden bridge, this is the watch in question:
And here is the movement:
I removed the screws on the bridge to discover........
A second bridge hidden under the first.... This is a new one on me, has anyone ever come across this before?
Could anyone have added this for no reason ? Different watch company, Different jewel count. The second bridge has chanfered edges so why obscure that detail. Why have cap jewels over the center wheel and third wheel bearings. Are there cap jewels on the opposite side ?
Hi It seems an expensive way to have fitted for no reason as they have to manufacture th bridge fit the cap jewels etc, probably found it cheaper than fitting settings with cap jewels but again that seems a bit odd as  reaming out the plate and fitting the setting in a manufacturing environment would be easy enough. The only way to find out if the other plate is the same is to have a look.  they maybe had an ednshake problem and that was the decided remedy other than re doing the origional bridgr.
13 minutes ago, RichardHarris123 said:
Some decent theories but none explain the change of name.
Maybe we missing something here but i think WW's theory is very plausible.  It has a patent on its design, so it was designed for a reason so what or where else could it actually be used if not here. So another company designed this part to overcome an issue, the two companies may also be connected in some way. It also may have been designed for a 19 jewel version of the movement which could explain the addition of the two jewel count. Cars gets recalls and revisions.
21 minutes ago, spectre6000 said:
The part that has me thinking is the 17 + 2 != 21 piece. It's missing pieces in that first movement photo; is there another faux bridge that's gone AWOL with the other 2 jewels? Is there another faux bridge on the dial side?
Interesting indeed, but would these additional cap-jewels add to the quality / performance, or just be an US(?) jewels-count sales trick 🤔
I can't see how the cap jewels would add to performance as the pivots aren't through the jewels.
2 minutes ago, mikepilk said:
The jewels on the 17 jewel bridge look just like normal jewels, so the cap jewels aren't actually doing anything. I agree @Endeavor, looks like a sales trick.
We were texting at the same time.
Seems like a lot of effort to bump a jewel count, more so considering the patent registration. Nice if we could trace the patent to explain its design.
Is the height with the 2nd bridge installed flush or above thd barrel bridge.
On the contrary, they may not even be real jewels, just bits of plastic or coloured glass pressed it to a cheap bridge. An easy way to bump up the price. I'm pretty sure it's an AS 1430 family, which does come in 17 or 21 Jewels ...
But the 21 jewel version looks like this, with caps on the gear train (but still not clear how it has 21J )
Hence this looks like a scam 🤣
Edited by mikepilk
Still seems like a lot of effort and curious as to how the patent was passed without a legitimate reason for a required design. Considering that the caliber was manufactured and used elsewhere with no modification. Money talks and Sears were the biggest department store in the world at one time.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
    • ha ha looks like a WMD.....you know I want one now
    • I took a chance on a non running Cosmotron X8 ("perhaps just needs a new battery" said the advert). Sure enough, I open it up and it has the wrong battery installed (a Renata 344 rather than the correct Renata 386) and the screws holding the battery contact had been sheared off to half a head on both ends. Ho ho, I thought - there's the problem. I got the broken screws out easily enough and as soon as I placed the correct battery in place the balance started. This picked up speed when I reinstalled one side of the battery contact and looked like it was a runner. As I was trying to get the replacement screws in, I did one side but the second was a bit of struggle (hold down the battery contact against its spring while dropping the screw in with tweezers) the balance stopped again. This time it wouldn't start again. 98 percent sure that I didn't stick anything, anywhere important or break it in a mechanical way. The battery was in place for most of the struggling with the contact, so it might have had an intermittent connection which could have upset the electronics. I tried giving it a puff with the blower but the balance doesn't seem to rotate in the normal way, it seems to be held in a static position by magnet. It can be pulled out of this position but spins back and stops dead. This may well be correct for all I know. Anyway, does anyone know anything about these watches and can tell me how I would go about and fault find this? I will be servicing it at some point so should be able to rule out mechanical issues from an old watch but not sure where to start with the electrical part of it.
    • Sorry to reopen a necro-thread (long dormant) - I have a Seiko Kinetic 5M42A that needs at least one coil, possibly both. Anyone know of any sources?  The usual fallback of eBay has failed me - there are people selling coils, but not the ones for this movement (which was apparently a very popular movement, used in Seiko and Pulsa branded watches.) The coil numbers are: 4002 516,  and 4002 519 I'd also love to find a source for spares of the screws used all over this movement - they're Seiko PN 0022 247 Thanks! (Moderator - if this should be a new thread, please do feel free to tell me, or drag this one into a new thread.) Don Eilenberger
