6 minutes ago, Endeavor said:
That's why I try to get to the source. Once the basic principle is understood, the rest is a logical consequence.
If the theory is correct, than Indeed, the amount of wobble will be the thickness of the shaving = amount of asymmetric.
The logical consequence would be that the to be reamed hole has to have the freedom to float by the amount of asymmetrically and can not be clamped fixed in relation to the reamer.
It's a bit difficult to explain in a non-native language, but I do hope that you get the drift of what I'm trying to explain 😉
Makes total sense to me
It's much more convenient tapping the part in center with the spindle vertical.
That seems to be a lot easier
Here's some pics of my scope. It's a simple setup with a B8 shank that fits the tailstock. Ideally it would be adjustable in one axis, so the cross hair can be brought over to the hole edge, but as long as the hole fits the field of view it works.
What a lovely set up you've got there @nickelsilver
4 hours ago, Endeavor said:
Thanks for that John, now the have the Seitz side of the story, which corresponds with what already has been said.
I was trying to get my head around as to the why the reamer creates the movement, does my theory above makes any sense?
Ah so the holder doesn't attach to the tool its just hand held and the movement from the reamer is just an effect of that design of reamer.
I think i understand now Endeavor. Because the reamer has only one cutting edge the hole is growing in size  asymmetrically around its circumference. So the backside of the reamer has to occupy an increasing asymmetrical space. The amount of cut thickness it takes equals the amount of wobble.
Perhaps we are talking the same? In my virtual brain picture the asymmetrically doesn't increase, it is constant but shifting its position during the rotation, provided you ream with the same downwards pressure, i.e. the thickness of the shaving stays constant. In fact, the asymmetrically decrease towards the cylindrical part of the reamer, where the reamer tapers off.  The "problem" with this type of reamer is that the back-side of the reamer (the non-cutting) leans against the borehole whereas the cutting side digs in, enlarging the hole. One could see it a bit as following an increasing spiral predominantly in the horizontal plane.
Correct. I do agree that there are nicer, perhaps better ways to enlarge a hole. Reaming with a one sided cutting action reamer seems crude, but, in the end of the day, if it works, it works.
I drool over Nickelsilvers machines, but those I may get in my next life 🙂
For now, and to me having solved the initial question, I can ream with these Seitz-reamers, when following the correct procedure, and be confident that I'll end up with a nice, in center and cylindrical hole.
Crude, cheap but effective.
I thank you all for your input ....... I think this was a thoroughly enjoyable and interesting discussion 👍
Edited by Endeavor
Thats exactly how i see it.  I meant the hole is increasing in size but not symmetrical, growing gradually as the cutter makes its way around the circumference of the hole. I think everything has been covered now haha
Beautiful set up there @nickelsilver. What do you use to grind such a fine boring bar, rather than buying them? I'm practicing honing some boring bars at the moment, but need a finer and better grinder
Fine boring bar ? Is that the large chunk of hacked steel with the tiny cutting edge Jon ?
Edited by Neverenoughwatches
It's a brazed carbide turning tool ground to bore very small holes. I think that one will do less than 0.80mm bores. In the hole is a plug gage showing the hole size.
I use diamond grinding wheels. In my early days (like slightly pre-2000s) used a roughing wheel in a crappy WW lathe, then honed on a copper disc with 3 micron diamond paste. More recently, a proper grinding machine, with diamond wheels, rough and finish. All freehand,  and for tiny things like this, finish the functional faces on another (lathe object) with a really fine, D7, diamond wheel.
Yes, that's it
  • 1 year later...
On 6/6/2023 at 10:57 AM, VWatchie said:
Yes, they're tapered, and I would suspect you're 100 per cent right.
I don't think reamers are tapered, I thought it was broaches that are tapered
Reamers in jewelling tools are tapered to open the hole up by 0.1 mm and ream the last bit, but ordinarily reamers aren't tapered, just the tiniest bit on the lead edge
So reamers in jeweling sets are tapered all the way?
Sorry got it now (from HS Walsh website)...
Seitz Jewelling Reamers.
The reamer has a tapered shank. The semi circular cutting portion is followed by a cylindrical portion, the diameter of which is a hundredth of a millimetre less than that of the jewel to be fitted. When reaming the hole, push the reamer as far as the cylindrical part.
Advantages:
Reamers with a single cutting portion make for regular reaming and accurate centring of the hole. The cylindrical portion insures that the hole is absolutely straight.
Edited by iiwii
    • My profile photo is age 20, last century, but I still look exactly the same so I'm not sure it counts ¯\_(ツ)_/¯
    • Hello everyone my name is Tom and I and I am new to the forum and new to the hobby. I have always had an interest in mechanical watches and finally decided to pursue it. I’m going thru online trading and have purchased the basic tools to set up a work area. I’m really looking forward to learning and thank you in advance for all of your knowledge!
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
