Pocket Watch Identification!
Even the amount picked up by the smallest oiler can be too much. I made my own oiler with a 0.2mm wire. And I use the amount picked up by the smallest black oiler and use that to transfer an appropriate size droplet to the tip of my homemade oiler. The final amount of 9415 used is so small that it seems ridiculous. -
It will help with where to look if a line is looking rough , having a little beat error say .5ms to seperate the trace lines makes sense as well. Now I'm wondering if it could be either, depending which stone is struck first as the timegrapher starts recording . That would be really unhelpful ☹️ -
Not sure how/why I started using 9415, must have picked it up from some forum or youtube I suppose and I used to slop this stuff on with my largest oiler... now I use my finest oiler and under highest microscope magnification, and I have seen a difference. what do you use on your pallet stones, epilame and...?
Actually a good question, I haven't thought about it before. -
I'm getting a little blip on a trace line at the moment and wondering if my lubrication isn't as good as it should be.
