I have a brand new VD53B movement.....so far so good. The wretched thing will not change over the date! I can manually adjust it and when it approaches midnight it BEGINS to change but then falls back to the date it was originally set. The stem is new...using the factory stem.
Thanks in advance for feedback and enjoy the weekend
Todd
probably something is badly fixed by this Cie I don't know because now, the watches are made in series depending the brand...it may happening that a movement is bad aligned on the line....anyway I understand me lololol
Edited by SeikoWatch
Does it happen with the dial off? If not then the dial may be touching the calendar ring.
