I have fixed friend's Tissot with an  F03.111 movement, the board was dead, so I just snagged a new one on Aliexpress and put it in with a new battery. Never even touched the mechanical part or the hands.
The watch was abandoned for quite some time and it is unknown how it ran before my friend decided to fix it.
Trying to troubleshoot the stopping, where can the fault lie?
- Stopped twice reportedly after some activity, tapping on the watch case made it go again.
- No clear time when it stopped, all hands were in different positions and not rubbing against each other.
- Have not observed stopping yet myself, have been running stationary for days.
- when put on mechanical tester without battery and applied impulses, the hands move no problem.
Any help or troubleshooting tips are highly appreciated.
Thank you.
When the movement stops, does it still have a pulse?
Most of the time, these intermittent faults are caused by dirt in the gear train. The usual culprit is dried battery juice.
You might have to do a full disassembly, clean and relubrication. Have you ever done a full service of a mechanical quartz movement before?
I just found this video on YouTube. The audio is terrible but it's a very nice video on the disassembly/assembly  of the F03.
The F03 has quite a few plastic wheels, which are very delicate. Be very careful when handling them. I wouldn't hold them by the pinions as seen in the video. I would use a blob of rodico instead. And when putting on the top plate, make sure all the pinions are in the holes before screwing down. The pinions are so delicate that they will bend if you breathed hard on them.
Good luck.
this isn't really a mechanical tester it's just a way of artificially spinning the gear train. Sometimes it will help to free sticky lubrication but usually is just a quick fix to get things running again. It's not a substitution for proper cleaning if the watch hasn't been serviced in a while.
if you get desperate you could also just replace the movement at the link below
https://www.esslinger.com/eta-2-hand-quartz-watch-movement-f03-111-2-6-date-at-6-00-overall-height-3-7mm/
then just in case you don't haven't I've attached the technical sheet which also has some troubleshooting information.
CT_F03111_FDE_296473_20.pdf
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
