Balance staff change.
cross referencing parts can be such an interesting so the UT 6310 at least according the parts list is supposed to have some form of shock system for the balance wheel. http://cgi.julesborel.com/cgi-bin/matcgi2?ref=UT_6310 I don't know if the staff heights vary because they're all listed in the same place but there are four separate balance staffs depending upon the type of balance wheel you have. So for instance the balance wheel with screws like yours would use a different staff than one without screws but there's only one listing for one balance complete so Balance complete should fit the watch regardless of which type it is. Basically it indicates that there was an evolution of this watch the older balance wheel with screws than the newer type without.
But here there are two variations of the 6310, the staff height will be different There are actually at least four variations of staff heights -
No idea Rich, but for your own sake please avoid inhaling the fumes.
I would try the vapour treatment very simple just a simmering pot of the stuff and jewels bluetacked ( not whitetacked this time, you still haven't said if I'm forgiven yet 🙂 ) to the underside of the lid. You're now gonna tell me that stearic acid can be highly explosive above 90° C 🤣
