Stuck pin in truing caliper
Hi all.
I messed up and broke the pivot of a fourth wheel I was trying to true up.  The pin is lodged in there and I can't remove it.  There is a hole in the stump to facilitate cleaning and removal. The truing caliper is what I think is called a lyre type.  Any ideas on what I can do?
Of course it's always best to reverse the part out, and you are 100% correct in saying that the hole is there to facilitate cleaning and removal of broken parts. So, that's where you should concentrate on. There are still a few unknowns which only you can see/know, like is there anything of the pivot visible in the cleaning hole, how much pivot is in the stump, with how much force was it pushed into it and what's the shape of it; conical or cylindrical. The shape and diameter of the part determines whether, as very last resort, you can push the part further in and out the cleaning hole, but that should only be attempted if everything else has failed and there is nothing more to loose.
But your main focus should be to reversing out with any idea you may come up with. Perhaps a sharpened / pointed steel paperclip-tip, with the tip bend to an angle (say anywhere between 60 - 90 degrees) so you can access the pivot hole from the cleaning hole? A screwdriver as an aid to increase the down-force on the paper-clip?
Needless to say, you have to get the stump out of the tool to work on it.
Perhaps others do have other idea's which may help you?
Suc6 😉
Edited by Endeavor
Not that I'm aware of, but people are creative 😉
I think that this truing-tool is mostly used for truing balance-wheels. I'm far from knowledgeable regarding truing, but one would assume that a wobble in the balance wheel has a far greater effect than a 4th wheel. After changing out a balance-staff the balance wheel can be out of true, but for a 4th wheel to be out of true, something more drastic must have happened 🤔
Anyway, suc6 with the "unplugging" 😁
Edited by Endeavor
11 hours ago, praezis said:
If the broken pin is long enough to reach into the hole, push it out from the hole with a screwdriver.
Else push it to the hole and remove from there (if too long, break it in the hole).
Frank
Just for my own education; what is the difference between what I suggested (above) and what you are suggesting?
Edited by Endeavor
Calipers often have two types of end pins, a set for poising and a set for truing. The truing pins have a conical recess at their end that holds the cone of a pivot, rather than the pivot itself which wouldn't withstand the pressures of truing. The side hole i assume also allows the pivot to pass though untouched while being trued. Poising pins just have a hole or a spring loaded jewel bearing in the center for the pivots to rest in.
The something more drastic is me being clumsy 😓.  Anyway I'll try to make a pin with a little bend at the end and see if I can push it out.  The pivot is not visible through the hole.  I really don't want to push from the front because I'm scared I'll mangle it.
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring it is still good. II am awaiting the replacement setting, and I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
