Servicing My First Chronograph!
Hi,
I just did a quick search on ebay and found a balance complete for the 7733 that ran about $80.00. You might get lucky and find a donor movement with a good balance for only slightly more which would then give you more parts for more projects.
Charles K
Hi,
Charles K
Thanks for your search. $80 only for the balance is a high value as with postage and customs taxes I would pay about $140!
I think it is worthwhile, as you say to look for a donor movement, if I can't get a cheaper solution replacing only the hairspring.
Good morning GuiBer.
Could you please post a picture of the damage? If it is just bent, it might still be salvageable.
Hi Geo, I would be very good if that was the case, but unfortunately the spring is a write-off, as when I was trying (stupidly!!) to force the incabloc spring to its location with a 0,6 mm screwdriver, that (of course!) slipped into the hairspring, "killing" it instantly!!
( I don´t dare to put any photo of this disater, as I don´t want to cause any health trouble to sensitive watchmakers!!)
P.S.- I have already discovered why I was encoutering such difficulty to put the new incabloc spring into its location: a tiny, almost invisible part of the prevoius one that I broke trying to remove it, was still there preventing the new one to get in.
Thanks for being considerate GuiBer! :D
It is a shame about the spring, but I'm sure you will retrieve the situation eventually.
Fortunately I have just bought on ebay a replacing balance wheel NOS from U.S for $30 (+p.p.)!
Just have to wait it arrives in 1 or 2 weeks to complete my job ( I hope! ).
Meanwhile I am still having problems to fit the incabloc spring (where all the problem began!). Nevertheless the incabloc is now clean from any debris of the previous spring, I'm still not able to fit a spring on it !!
So, I'm considering to replace the incabloc with a complete new one, but for doing that in a proper way I shall need a special tool, isn´t it?
I had the spring fly off, I must admit, a couple of times though. To put it back in what I did was grab it with my tweezers from the bottom part and insert it diagonally in the slots on the incablock hole, where it is supposed to hinge. Then I twist it carefully, pulling it to feel if it grabbed the slots or not. I pull really gently since the risk of braking it is way too high.when I feel some resistance I let it go, and lower it in closed position to see if it was fitted correctly. Hope this helps.
Yes, of course Georges, but what happened (as I wrote in a previous post), was that when i tried to open it (in a wrong way) for lubricating the jewel, it broked!  So I had to order a replacement (sold in sets of 5), which I am now trying to install.
I don't think you are supposed to remove the spring, but just to lift it open, like I did in this picture:
http://www.clarkson.it/landeron/hema/service/service_hema-28.jpg
I'm doing it approximately like you do. Do you do that pushing the string from the inner side of the incabloc or from the outside?
( I had tried both ways wihout the jewel in place)
Thanks for all your help George!
I'll give it some more tries, before I decide to replace or not the complete incabloc, which may also not be an easy task without the proper tool!
P.S.- The balance wheel I bought today in ebay (as I told in previous post) was that one you informed me about yesterday, but I offered "only" $30 against the $80 the seller initially wanted, and to my surprise he agreed!
    • Thanks Rich, its really not that difficult to make them, simple ones anyway. Cousins didn't have the part though i could find it on ebay at 6.50. I figure i earned about £1.50/ hr . It paid for the diamond files i bought.
    • If you look at this thread, you can see I had exactly the same problems with balance springs with 2 prongs on a Smiths 627. The slots in the chaton were not big enough to get the ends of the spring out. I had to bend them to get them out and back in. Not ideal. I don't fancy having to do it again as they could easily break, and where would you find replacements? I didn't come across the 3 prong type.
    • I visited the Breguet Exhibition today. https://www.sciencemuseum.org.uk/about-us/press-office/rare-timepieces-unveiled-new-display-science-museum The Science Museum now holds the collection of "The Worshipful Company of Clockmakers" - "The collection includes more than 600 watches, 90 clocks, 30 marine chronometers and a number of fine sundials and examples of hand engraving, mapping the history of innovation in watch and clock making in London from 1600 to the present day." It's well worth a visit. They have some amazing pieces by the likes of Harrison, Breguet, Tompion etc . I've visited twice before but decided to go and see the Breguet Exhibition. Maybe I was expecting too much, as on reflection, "More than 20 extraordinary timepieces designed by inventor and watchmaker Abraham-Louis Breguet " isn't going to take up that much space. In reality, it's just one cabinet. But, Oh those watches, stunning 🤩 , e.g. (No 1297 was made for George III and is valued about £1m)   I tried a couple of pics, but with subdued lighting and taking through glass, they aren't good. I like thin hands on a watch - how about these (I think this is a split second chrono)   And this one, with all it's complications, is only 10mm thick !   What I found very interesting were a few very old machines for making watch parts, like this 17th Century gear cutter. The disc below has concentric rings with holes in, so that is can be set to cut varying teeth numbers.
    • Firstly sorry for poor image quality I only have an iPhone for photos.    Im working on a 512 movement and I’ve had some trouble with the “jewels”. I’ve got the metal one out, but when I tried to put it back the three sides of the spring seem to need pressing all at once to fit it as there are three “holes”. I get two corners in but as I go for the third the first two pop out! Constantly I’ve lost the spring. I’ve done the similar ones on seiko movements without trouble. Assuming I find it/a replacement, what am I missing!   on the other side with the only ruby in the movement is a setting with no “gap”at all. How do I get the spring out, and of course get it back in!    What am I missing!    thanks in advance.    Rob
    • Links like that are the reason I routinely donate to the Internet Archive - they are the last safe house for a tremendous amount of useful info that is otherwise lost.
