Timex M24 Manual questions
not a lot of information on this watch unfortunately. Best fit only list three entries. the next one is ruled out because of the shape
Very nice well restored watch Rob, looks like the tube did brake off the original second hand. -
There is a little difference in keyless works, but I believe this is the caliber, or at list the manufacturer -
By rjenkinsgb · Posted
Try taking the strap off and see if there is a notch for a tool or knife in one of the strap recesses? I've never seen one before but suspect it is a pry-off type, as it seems unlikely the text and logo would always be in perfect vertical alignment if it was a screw-on type? -
This is one I've had for a while, 1020 movement, bought with a setting fault - but it was running and setting fine after a service. Until the second hand fell off! I initially thought I'd not fitted it properly so re-fitted it - and it fell off again within a few hours. I then realised after looking at parts on ebay that it should have a bush or sleeve and the one I had was missing that. Since then I've been hunting for parts, then getting around to re-doing it as it's probably the most valuable one I have and I'm still nervous with anything that has difficult-to-get or expensive parts. It was also missing the hack, which originally I was not bothered about as the plastic part seemed rather dodgy, and the date ring print looked worn. I got a date ring, hands and found there was an alternate metal hack so got that too. The hack is perfect, hands great - but I'm not sure of the date ring? It fits the movement, but is thicker that the one that was in it and looked like it may scuff or jam on the back of the dial? I've left the original one in for now; that does have some clearance behind the dial but I'm not sure if it is enough, or if there should be a dial spacer that I do not have? See the photo. I do suspect it has been got-at to some extent in the past, as the hands that were on it look slightly tarnished and the seconds hand is a slightly different length to the one in the new set. There is a slight mark on the dial around the 9 o'clock index; I have no idea what that is but I don't like messing with dials in case I make things worse. Whether or not the date ring is correct, it looks nice and runs well, definitely a good smart wearable watch!
