Micro drill bits.
40 minutes ago, RichardHarris123 said:
I had to drill out a broken case pin, luckily I have some micro drill bits but I'm not sure about the quality.  Can anyone recommend a good make and where to buy them?
🤔 been thinking the same Rich. I have some unused vintage drills that go down to 0.1mm, and some cheap crap . Ive been looking at some carbide bits to try.
Just checked Cousins but £54 a set or £6.50 each.  A happy medium would be good.
So i bought some cheap carbide drills after our discussion and they arrived today. Compared to the supposed hss bits i bought a while ago which were rather naff, these are far better. I cant comment on the steel quality but they have very good sharp accurate cutting faces. Ten drills from From 0.1 to 1.0 mm. Up to 0.2mm the edge was sharp , the 0.1mm at the half the size was difficult to see even at x 40 but yet to view through another biological scope i have. Still find it amazing that a cutting face of 5 hundredths of a mm is a thing.
https://www.ebay.co.uk/itm/175352784092?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=wWJ9ztuQRi2&sssrc=2349624&ssuid=tBiLZaCfRb2&var=&widget_ver=artemis&media=COPY
I'm not going to need any for a while so keep me posted on how they perform.
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
