Proud Moment!
If you have an apple device and download the app linked in @deni2s's post the search function works properly.
ok, have you try a watch that twist the bezel to open it? and use what tool? I try to pry the bezel and it does not work.
This is the link I use to Ranfft :Â Â https://web.archive.org/web/20230305223408/http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk The search function doesn't work, so the link should show all the movements.Â
By Hawaiikook808 · Posted
Thanks, Praezis. I'm going to hunt for one. -
Why do you doubt? It is a common current name for transistors with included base and base-emitter resistors. They are not „digital“ by itself but can be used in digital circuits without added components. Frank
