I've looked on the site for information for the distinctions between these two movements.
They;re both ST36, one is further delineated as P29. For the life of me, I'm unable to find the alphanumeric name of the other one. Apologies if this is somewhere on the site, I've looked and haven't found it.
Anyone know their names?
Answering my own question here, please correct me if I'm wrong. The movement that Mark uses for the tutorials is ST3620 6498
The other movement is ST3620 6497
When buying a movement to follow Mark's tutorials, I'd bought ST3620 6497, I was befuddled a bit however I got through it.
These of course are Chinese clones of Swiss watches. This means that getting anything resembling any sort of information is impossible because the Chinese don't do information at all. But if you looking for the difference between  6497 a 6498 that's easy.
Oh then there's the other difference the original of these came in 18,000 beats per hour then they put it –  two for second-generation and that's 21,600. I have a link below for each one of them so you can look at the dial side and see with a little secondhand goes. So the 97 the crown is at the 12 o'clock position in the secondhand is at the 6 o'clock position. Basically what I would call your standard pocket watch.
Then the 6498 and it's even noted on the link below is the hunter style case.  This is the watch you pull out of your pocket that has a lid the crown is found at 3 o'clock position versus the 12 o'clock position and the secondhand would still be at the 6 o'clock position
Then either watch will work fine for the class.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&ETA_6497_1
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&ETA_6498_1
If you compare the images on ranfft with the winding stem at 12 o'clock you'll notice that they both have 3 bridge plates. On the 6498, the ratchet wheel is located around 2 o'clock while on the 6497 the ratchet wheel is located around 10 o'clock. On the 6498, the balance wheel is located around 7 o'clock while on the 6497 the balance wheel is located around 4 o'clock. The Chinese ST36 has 4 bridge plates (a separate plate for the pallet fork pivot):
My drawing skills suck but you should bill a see where the stem comes in and you look for the balance wheel jewel because it's unique and then it goes to the pallet fork escape wheel and the fourth wheel which carries the small secondhand. Then what happens with the Chinese watches there will be a whole bunch of variation of plate styles but the gear trains have to follow the same path because they're all meshing together
    • I think we've talked about this before, using a new mainspring to initially overcome the effects of more movement friction than there should be. The aim is to reduce all going friction not to push through the friction with more torque, that in the long run will create more wear.
    • Sensible precautions @rjenkinsgb. I remember as a lad, my mate's dad ran a garage. I can clearly remember watching him change break pads. He used an airline to blow the dust out, (when pads used asbestos), and  we used to practically bathe in "carbon tet". But then he did smoke about 40 cigs a day. Makes me shudder to think about it.
    • OK, a little bit more from today's lecture about the main springs. Generally, the spring in the barrel is limited and can't  unwind fully. With the blue line is shown the reserve/torque relation when spring unwinding is limited by the barrel. The green line represents the same when the spring is free to unwind fully And the red line shows the minimum torque that is needed for the movement to keep running. The yelow graph shows how the torque changes (from the blue) when the spring gets weaker (set) after 100 years of work. The purple line represents thinner and longer spring in the same barrel. As You can see, using thinner and longer spring will increase the power reserve. The 'set' spring will have the same reserve as a new one with the same sizes, only the amplitude will be just a little smaller.  Of course, this is true only when the movement othervice is in good health ( the red line is lo enough)
    • As long as you don't grind the stuff up and blow it around, you should be fine. Use a dust mask if in doubt.   The things I'm very careful of are: Radium lume - even the stuff that is visually completely dead and inert is still highly radioactive; it's the fluorescent part that decays, not the radium. A single speck inhaled or ingested can cause cancer, so store parts in zip bags and wear a dust mask & wipe your work area down after handling anything that uses it. A proper geiger counter is a good investment if you plan on working with vintage watches, so you can check for it & take appropriate precautions.   "One dip" & equivalents - the original type & the generic PERC dry cleaning fluid (Tetrachloroethylene / perchloroethylene) which is what the original one dip was mostly made of. That's toxic, a known carcinogen. Use in very good ventilation only & keep it sealed whenever possible.   The newer B-Dip is presumably a safer replacement.
    • Only 137% !  sounds like you're not putting enough effort in 😆.  I would think of it like cogs on pushbike.  Fastest speed to the spindle would be largest pulley wheel on the drive and smallest pulley wheel on the driven. If the motor was into a sliding bed you would have 3x4 ? Speeds.
