I've been meaning to post this in the hope this may help others as I know there is a following for these. I didn't come across much on the old internet.
It's been a slow burner (well over a year) as when another pops up. Most I've seen have all had battery leaks and/or missing battery contacts. As with this hobby you seem to end up with another watch in the hope of fixing the one you have!
Mine started with one that came in a job lot, managed to get the digital side of things working, but the very fine wires on the coil are broken. Analogue side no go. I didn't have enough magnification at the time. Then I managed to get a second one in the hope of swapping parts to make a working one. That's when it got interesting as it seems a Timex V Cell Ana-digi is not all it seems I guess on at which point in time it was made. From the outside they look almost identical.
Once you get inside you can see the subtle differences between them. This sadly prevents swapping the circuit board, coil or even the movement holder, or to fault find/getting it working
I guess the 6 jewel version is the older one and over the passage of time to cut costs by Timex and HANDOK (Which I still think are around) the jewel count was reduced, along with a few other changes.
By good fortune and a lot of patience third time lucky I got my hands on my third which is likely late 1980's. This time after a bit of cleaning and repair to the battery contacts this one worked.
Any way the one above sits proudly in the collection now. I hope this may help someone on a similar quest, not all Timex V Cell Ana-digi's are the same..... perhaps there's another version out there to add to these?
the early LCD Timex also appear much alike but are not.  An  example is the display glass will seem to be an easy swap from one to another.  but you will soon find the best result is that the segments will fire up but not in anything that looks like a number.   I've never come across  good factory resource of knowing how to identify the characteristics of the modules.  So just as uou state one job lot find soon becomes a pile of mix and match projects.
Hello JerseyMo, you're very right it's so very easy to end up with a pile of mix and match pieces. I did a module replacement on a more modern T80 a while back although it's identical in features you're right there are subtle differences.
For my v-cell the initial hope was in finding a replacement coil in another but it wasn't to be. I've no idea if Han-dok made modules for anyone else in attempt to track down a replacement. One thing I did notice between the first one I got the digital side of things working and that of my fully working version is the alarm sound. On the partly working version it sounds more urgent towards the end.
In the timex ani-digi world I've seen the K-cell version which I think is older but not by much. On first appearances this looks almost identical. Not ready for that rabbit hole unless one turns up in a future lot.
  • 2 months later...
Ihav 1of these watches .hardto tell only difference I can make out is on the back it says lift here at top. At bottom. Assembled in Korea. Can you use it. Asking b4 I trash it looks very good. Pennsylvania. 6109611123
  • 4 months later...
The six should be an eight, sort this and all done
Edited by Babelman
have one very similar, very new to watch repair, analogue works fine, a few segments not working on LCD. Have removed scratches from Cristal. Hope finish it next week.
Nice watch Babelman, and it looks like you have an original strap. Another subtle style variation.
I reckon if you carefully clean the zebra strips you'll get back all those missing LCD segments. It's great that the analogue works that's normally the part that doesn't because of a leaked battery.
Any chances of a photo or two of the module?
Also does the alarm sound consistently, or does it become more urgent toward the end of the sounding? That's one thing I forgot to mention in my earlier posts.
Good luck
Good luck
Hi thanks or info, trying it now. Here is module photo
Forgot to mention Alarm not working, maybe it will after cleaning etc, will let you know if I get back LCD, hope so as always liked this watch, never got one when they came out new.
Looks like you've got the 6 jewel version, nice.
In regards to the alarm have you got the small piece of plastic (red in colour) which goes over the spring contact, like in my working version picture? It's likely shorting out hence the alarm not working. If not you could use a tiny piece of plastic bag and or tape to test it out.
Just now, Babelman said:
Had a nightmare negative (lower) battery terminal broke, will have to try and get a donor watch for the part.
Managed to find a donor watch, will fit part and hopefully all good.Will test out the alarm properly too.
Would've got back to you sooner but I've been decorating!
You did well to find another as a donor. Is it identical to the one you have already. Any pictures of it if it isn't? That's the rabbit hole I started down only to notice the differences. I too had a busted lower battery terminal but I managed to modify one from another broken (not timex) LCD watch.
It looks visually the same, module same type but lower amount of jewels
Will let you know how it goes.
Fitted replacement part, all working fine put back page on and lost both functions. On inspection found the replacement part had broken. Back to square one..
Oh no. I share your frustration. I had the same problem with the lower battery tab. You don't have to hunt another exact donor (although useful) you could rob a contact from any other scrap digital watch.
That's what I did, with a fettling I got it to fit a treat. Have you any photos of the busted part or do you have any digital watches kicking about?
Did you get those missing segments back? Good luck
Didn't get long enough to check segments,both analogue and digital working though which was my main worry,will try to make a replacement, at work at the moment, when I get home will take a photo.Its like a letter T with two 90 Deg bends.Cant justify spending on another donor, postage is a killer price wise.
IMG_20230928_135419.thumb.jpg.c26ea12ae4787fc1c3a312bb8b15a188.jpgThis broken tab, will try to make one up
That's a pain that Babelman, any luck in making a new one.
rehajm, I think "unadjusted" is a historical thing which looks to have been carried forward onto these Timex's. I've seen mechanical movements with the same, or with such markings as one or two "adjustments".
I'm now going off to find out more myself, good question
I did try, using some donor parts, but so small don't have anything to trim and hold it with.What did use use? I am thinking of using some tinfoil, as easy to fold, maybe a touch of super glue to hold in place, at work until  Wednesday, so will try on Thursday.Any advice welcome.
How you progressing Babelman? I'd try and avoid superglue it has a tendency to go places it shouldn't. Do you have a small pair of pliers and sharp wire side cutters? Jewelers needle files helped to.
I assume you've got some tweezers too. Below is a donor (cheap and nasty digital watch) I used full of useful metal parts ready to tweak to shape.
Some gentle bending with the pliers to correct the shape, a little trimming and filing I had a replacement lower contact.
That looks a very neat job, I do have those items. Do you have magnification or brilliant eye sight?
    • Looked into this some more and I believe that some of the increase in rate is attributable to the drop in amplitude after 12 hours off wrist, from 300 to 275 degrees horizontal and some is due to the lower temperature (38 to 18 degrees). I can see that approx 3 to 4 seconds a day is attributable to each. I can be happy with that.
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
