Centre seconds, time adjust by key, as you can see from the photos there isn’t a stem hole. Only a chamfered gear for winding.
I’m looking for a case for this type of movement and was wondering if there was a particular name for this winding set up/ case for this movement?
cheers guys
Key wind / Key set I often see abbreviated as KW/KS.
Curious, this movement is set up differently from the American ones I'm familiar with. What does the key look like for setting the time? And you mentioned center seconds, how does that work?
Key looks like any other pocket watch winding key, if you look between the Hawley and son engraving on the plate you’ll see the square for time adjustment .
as for centre seconds, it works the same as a wristwatch train does.
I've seen this before unfortunately it's a problem. As you can see there is no stem and no key winding or setting. I don't think I've ever seen the case so the case itself would have to have a gear to mesh with the Gear on the side of the movement. Then the setting is pin set. If you look at your picture a little farther down you'll see a steel  part that can be pushed in and when that pushes in the movements in setting. The case itself would have a protruding pin that you push in to go into the setting mode.
Cheers mate, happy with the explanation. It’s got a key set for time, and happy with the slider on the side to activate the centre seconds and the pin set next to it.
just need to see a case so I can see what I need to look for
