Hello all,
I am new to the forum and would like to let you all know a bit about myself. I have been interested in watches for 40 years as a collector and have a few in my personal collection although my wife would argue "to many watches" 🙂. I reside in the United Kingdom and have done for the past 62 years. I have recently decided to build a watch from scratch using a 2824-2 movement and have uploaded a question to you on the forum for help.
Thank you everyone
