Pro or noob I want your opinion. What is it worth? What would you pay for it?
Here is an excellent prime example of a Hamilton Brandon model wristwatch. These watches were made from 1948-1951 and are 10KGF with 18K solid-gold numerals on a silver-color dial. This particular watch is a wonderful, very clean example with an original dial. Note from my pics how crisp and clear the dial is - especially the "cld" and the seconds sub-dial. Dial restorations do not replicate the "cld" as well as this original dial from 65 years ago. This Brandon has the original gold hands which are in perfect condition. There is no pitting anywhere on this watch.
Of particular note is that this watch was completely serviced (disassembled, cleaned, rebuilt and timed) by Rene Rondeau, the world's foremost expert on vintage Hamilton watches, who has recently retired. The last 2 pics were sent to me by Rene as he was working on this watch. He noted how nice the dial was (he also concluded it is original) and that the cal 980 17 jewel movement was also very clean. Indeed, this watch runs strong and accurate as a wind-up vintage wristwatch!
post-1256-0-34800000-1436287740_thumb.pn
post-1256-0-01805300-1436287799_thumb.pn
post-1256-0-64686000-1436287827_thumb.pn
post-1256-0-23733600-1436287937_thumb.pn
post-1256-0-80401100-1436287957_thumb.pn
I paid £140 sterling for my Hamilton 980 - around 3 years ago - they were quite a rare find at that time in the UK.
Hamilton watches are more common in the US, and generally go for fewer bucks.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
