Book that covers Staking
By steve1811uk · Posted
Hi, I just wanted to share the unmistakable quality of a Rolex made in approx. 1990. Cleaned and serviced for a friend using appropriate oils and greases, with Epilame on the parts recommended by Rolex. New mainspring and upper setting and jewel for the minute Pinion (cracked jewel). Run in overnight and then worn on the wrist for a couple of hours to warm. Without any adjustment to the balance weights the watch ran at 0 SPD DU, all positions within +3 and -2. Vertical amplitude after 24 hours of 230 degrees minimum. Watch running at zero seconds per day on wrist when worn 24 hours. Serviced just once before 20 years ago. No need to buy the Microstella regulator tool, not this time anyway 🙂 No scratches or damage caused to screw heads and bridges. All seals replaced and waterproof tested to 60 metres. All good practice for when the time comes to service my own Grand Seiko. -
By MariusJacob · Posted
My kid woke me up at 2:00 a.m. I couldn't get back to sleep so I decided to go to the workbench. I was to tired to work on a watch so I decided to dress up tweezers and screwdrivers while having a drink and listening to some music. Luckily I got a comforting nap after lunch and started working on this beautiful Raketa Big Zero. -
Good shout - I'll grab something like that and some around the required size from cousins too...
Hi, I have a lot of experience with Seiko and you can make all of those run within a few seconds a day with small adjustments to the Etachron regulator. You just need a timegrapher, an Etachron adjusting tool and ideally a stereo microscope, along with a bit of knowledge and patience. Not difficult at all for a watchmaker professional or a hobbyist like myself. -
Courtesy of my parents who are at the Henry Ford Museum (formerly Greenfield Village) in Dearborn, Michigan today - a photo of the watchmaker's bench setup in Thomas Edison's Menlo Park laboratory. This is a pretty good display, a pallet warmer, truing caliper, staking set (unfortunately closed box), spirit lamp, and check out that six jaw chuck on the lathe. The museum is a mostly an outdoor village where Ford had moved numerous buildings important to himself and to the history of technology in the USA. (Also includes the Wright brothers' bicycle shop for example). As a teenager I worked in an 1850's tavern there. There are several other large lathes too.
