https://www.printables.com/en/model/230373-barrel-closing-tool-for-watch-movements/comments
Specifically talking about this guy. A friend got a very expensive resin printer, I know NOTHING about this but i am a 3d modeler so i will be designing a couple tools which i'll post here in the future including a double sided tool for setting seiko diashock springs. Anyways he printed this out for me and he's not sure why but it doesn't appear to have come out the correct size and can't actually close a barrel. The diameter of the cap on the one he printed is .975 inches. Does anybody have the bergeon barrel closer this is a copy of handy and can measure the diameter of the cap so we can figure out what we have to scale this thing to to get it work?
@Birbdad
hopefully this will help
top part
outside diameter 25mm
inside diameter 22mm
arbour hole 3mm
overall height 14.25mm
depth of central cavity 9.75mm
base part
core outside diameter 21.5mm
base outside diameter 25mm
base height 4mm
overall height 16.5mm
arbour hole 3mm
top of core is convex, centre is approximately 1.3mm lower than overall height measured to the edge of the top of the core
Tom
Sorry, autocorrect gave me convex, it should of course be concave
3 hours ago, tomh207 said:
@Birbdad
top part
arbour hole 3mm
base part
base height 4mm
arbour hole 3mm
Tom
Interesting. So it is the correct size, it just is a crap tool and doesn't work haha. Not yours, the one i had printed.
9 hours ago, Kalanag said:
The inside surface of the upper part must be domed to ensure pressure on the outer edge of the barrel lid.
Yeah this one does not have that that i can see.
so I'm confused the tool is crap or your printing is crap or your printing of the tool is crap or something else?
On 11/14/2022 at 7:14 AM, tomh207 said:
@Birbdad
Dimensions
Ok this is amazing. This will make things so much easier!
I think this guys design is crap haha. This could open a pocket watch barrel but it's not even close to being able to open a normal watch barrel. When i put the barrel in and put the top on there's so much space between the flatceiling of the top and the cavity in the bottom the barrel just rattles around in the thing. THe printing itself came out perfect.
So messing aroudn with redesigning it and looking at vids of the bergeon one, it appears the ceiling of the inside of the top part is flat.
You're saying both sides are  domed/concave? It feels like the top surface should be flat since it feels like that's putting a lot of pressure on the teeth of the barrel. On this guys design the bottom part is domed but not the top.
Edited by Birbdad
I was being confused I would normally agree but is that really how the tool is supposed to be used? I normally don't use the tool can as I'm trying the close pocket watch barrels and they just won't fit in the one that we have at work. I was looking to see if I had dimensions anywhere because this is a school project they make it at school or can make it at school like the PDF that's attached.
But it brings up a problem I snipped out an image tool doesn't exactly work the way I thought it was supposed to work.
Then found a video shows using the tool.
https://youtu.be/FIM2LZ1JEBY
Wostep Barrol closer CCF12182012_0001.pdf
wait wait wait @Birbdad. You trying to open or close the barrel? That item is for closing the barrel, there's no tool for opening it. That being said, why not just buy the closing tool? They're less than $10?
You can't open a Seiko barrel like the guys show on YT, you'll bend the top cover. You'll have to gently separate the two halves using a sharp knife or small sharp screwdriver. It takes practice to do that without marring the barrel.
Edited by gbyleveldt
You're on the ball today matey, beat me to it, i think Col just got opening for closing mixed up though.
Whut, i'm tryin to close it XD if i typed open that was a mistake.
And the bergeon tool is 40 bucks because of course it is. Where are you seeing this for 10?
really my buddy wanted to test out his fancy new resin printer and this is free.
13 hours ago, tomh207 said:
Mine it is the core of the base part that is concave on top
Yeah that's what i figured. It looks like whoever modeled this one made the concave part too deep and the side walls of the top part too long so the flat top of the top portion doesn't contact the barrel.
Lol Col . Knock 30 bucks off that and you have a bergeon one that doesn't have 30 bucks worth of Bergeon lettering spelling out the name Bergeon. 🙂
But the word bergeon is what makes it a REAL tool!
I have plans to model and 3d print a tool for setting diashock springs. I"m going to model the word bergeon into it so it works better.
23 hours ago, grsnovi said:
Just measured my Bergeon 7922.
Oh fantastic! I'll pass it along!
Edited by Birbdad
Haha. If thats true then I'm having Bergeon tattooed on my forehead this weekend.
I tattooed it elsewhere. The misses is pleased.
Hey this is great. Maybe it's not clear but is the 1mm the width of the hole for the arbor there or is that the depth of the concave in the top of the core?
As per the dimensions I posted the holes are 3mm, the depth of the concave surface on mine is approximately 1.3mm. Gary has posted his measurements and the depth of his concave surface measures to be 1mm
Tom
Yes, the hole through both pieces is 3mm. The depth of the concave was "estimated" to be 1mm since I don't really have an exact way to measure that. Based on the design I doubt there would be a functional difference between a depth of 1mm v. a depth of 1.3mm. I used to have a routine that would allow me to calculate the radius required to cut a diameter based on three points but I wasn't in the mood for trying to dig that out. Not sure how the 1.3mm was determined since there is no material at the center point of the depth.
Also, I didn't measure the ID of the upper piece as it will need to be 21.5mm plus whatever the nominal slip fit clearance needs to be. Again, if the top doesn't have an exact slip fit it will not impact the function of the design.
Hey Gary, it was an approximate measure as I could use the depth measurements using my calliper which gave me the depth with one part on the edge and the “stick” on the edge of the hole. Hence approximate.
Tom
Hi Tom,
Mine too but I laid a steel rule across the top and then used the extended end of my caliper but I just eye-balled it and figured 1mm was close enough for gov't work 🙂
- Gary
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
