I recently gave information about Timegrapher. I thought someone might be interested in my approach to homemade tools.
I made a mainspring Barrel press from two different sized shampoo tops. A small hole in the centre of each makes a gap for the arbour.
A £4.99 presto tool. Cutting a groove with a dremel makes it useable for 5 spoke wheel removal.
Spring saver whilst washing. Centre of a suction cap. Outer edge cut away. Inserted into the mesh basket, placed on top of springs means they do not get caught in the mesh.
Just loving the hobby.
Ross
Edited by rossjackson01
more information
  • Like 6
More home made accessory tools
Better show of Mainspring press
Better view of Presto 5 wheel extractor
Balance cock support holder (holes in top and bottom of plastic pots, pegwood insert)
Oil holder. Tape to allow easy opening and closing for use.
Movement holder. Base enlarged so that it does not fall over easy under pressures.
grammar and more photographs
I ĺike the barrel lid press Ross, i think thats a great idea. I know where you are coming from with the movement holder they can tip when placing any pressure on one side. With a tight screw or releasing a stem. Little tip with the balance tack as i hate to see the h/s stretching, place a piece of correctly sized foam over the shaft to create a table for the balance wheel to rest on. Use a dense foam as opposed to a sponge in case the pivot grabs . Something like an old yoga mat or those foam interlocking mats for kids.
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
