G'day!
Stevo2022
G'day Everyone,
I hope this is the correct place to introduce myself? I guess I'll find out soon enough. 🙂
I've been a reader of this forum for a while, and have been subscribed to Mark on YouTube and a follower of his on Instagram for a few years. I've always been interested in watches, especially dive watches. My dad owned a couple back in the 60's and 70's. I have started tinkering and modding Seiko SKX007s' in the past few years and making leather straps to suit them.
I decided to join the forum because I read a fantastic post on here about making bracelet end links from stainless steel sheet. That post has helped me a great deal in solving a problem. So, I wanted to come and say thank you!
Cheers,
Steve
20 hours ago, Nucejoe said:
Welcome to the WRT forum.
Thank you Nucejoe. Nice to meet you!
19 hours ago, oldhippy said:
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
Interesting intro so how about showing us some of your achievements.
Hi oldhippy,
Thank you for the friendly welcome! Sure, I'll show you some things I've been tinkering with.
I wouldn't exactly say achievements, but it's always a good day when the house is still standing at the end of it 🙂 The first pic is a SKX that I swapped out the 7s26 with a 4r36, SARB crown and a double domed sapphire with a bevelled edge to keep that Seiko look to the crystal edge. It's on a veg tan strap that I made for it. A piece of rotting fence paling completes the look. I know it's a dive watch on a leather strap, which is a major faux pas to some.
The second is kind of a 62MAS homage made from mostly Seiko parts-dial, 4r36, case back, SARB crown, click spring, and gaskets. The rest is all aftermarket mod parts-case, hands, top hat crystal, bezel, oyster bracelet, and bezel insert.
The forum post about making end pieces that brought me here will allow me to link the oyster bracelet to some flat end pieces I found at Cousins that fit the case.
What brought you here in the first place Mate? I'd love to see what you get up to also!
Cheers,
Steve
Hi oldhippy,
Cheers,
Steve
Nice mod Steve and definitely no problem with the leather strap it looks really nice and something i would enjoy having a  go at making. I thought the leather tools would be expensive but not especially so compared to the watch repair.
Hi Neverenoughwatches,
Thank you for the compliments about my tinkering efforts. The mods were pretty simple. I'm building up the courage to restore something. I guess I'm in the right place for that. 😆
To make my strap, I drew a template for the strap and printed it out. Then I taped the print onto a piece of 1.5mm vegetable tanned leather. I then pricked the shape through the paper onto the leather with a pin and cut it out with a scalpel and steel ruler. It's stitched with 1mm saddle thread and glued with a water based contact adhesive. I had a buckle lying around that was the right size.
If you get a chance, give it a go. It's fun, cheap, and rewarding. It'll give you another reason to look at your wrist.
Cheers,
Steve
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
