 I have a labeled assortment of timing washers.  I also have a small bottle of "assorted" timing washers.  From time to time, I take a timing washer out of a bottle and it loses its way back to the bottle from which it came.
There is no way to match them by weight with the tools I have.
Do I match them by thickness??
They all appear to be the same diameter (I have not done a thorough analysis of this).
  • 4 months later...
Apart from ebay, has anyone found a supplier of timing washers?
I have a nice set of pocket watch washers - the smallest are Size '0' (13''') which I can use on some wristwatches, but I'd like a better selection.
Twice recently I've had hairsprings break at the studs, which when re-studded, requires quite a few timing washers.
