Hello Everyone,
(please forgive my excitement over what must seem a rather mundane piece of equipment for those of you who already have one)
My 3L Ultrasonic cleaner has arrived, so I can finally start blasting the grime, dirt and wrist cheese off of cases and bracelets!  Yaay!  Does anyone have any experience with similar model(s)?  Any model-specific tips?  Of course, I have been watching some YouTube videos about how to use these devices...but any suggestions or additional "secret ultrasonic lore" is more than welcome!
Attached is a bunch of pictures I took to document the delivery, in case there was any transit damage (there wasn't).  I plan to fire it up later on today (or perhaps tomorrow) and test it on a bunch of grimy, rusty stuff that's been lying on the outdoor workbench...in closed, separate glass containers of course, so as not to contaminate the chamber!
g.
It looks almost identical to mine, except the label on mine is green 😉
Check the heater works, mine didn't.
What cleaning fluids are you planning on using, I use the Elma Red with good results but may try L&R Ultrasonic if I ever win the lottery 🙂
Edited by Paul80
Hello @Paul80,
Great hearing from you!  OK, will be checking the heater right away.
The unit arrived with a Chinese-only user manual, so I spent a little time today writing up an English version.  I wonder if anyone would be interested in taking a look and making sure I got everything right?  Is there any "Ultrasonic Cleaner Lore" that I should be including?
Ultrasonic-Cleaner-Manual-2022-08-17-Adocx.pdf
Looks exactly the same has mine. Mine has been a real workhorse. My heater works, but it is slow. Running the ultrasonic adds as much heat as just using the heater 🙂
The only tip I have is to make sure that there is plenty water in the tank when you run it, as I believe if you run it when dry the transducer may overheat, as it uses the water in the tack to cool. (see above).
Cheers!
Got the 2L version, wish I had gone bigger. It’s been really good for me and done a great job of all I have asked of it so far.
Tom
Cheers!
Hello @dadistic,
I have amended the instructions (attached)...do you think it's enough?
g.
@Paul80,
I don't know if you are handy (though as a Watchmaking fan you likely are), but the way I'd troubleshoot that is to UNPLUG the unit, open it up and check the resistance of the heating element (which is probably 100W) to see if its resistance is infinite (broken heating element) or really low (like  under 10 Ohms).  If you can get a measurable (but low) resistance then the issue is likely elsewhere in the circuit (maybe a fuse).  Here's a little discussion from Quora about heating element resistance levels and how their resistance changes when they go from "cold" to "hot":
g.
Edited by Gramham
Added image
My 1L version (DK Sonic branded) should be arriving tomorrow: 55W, 42 kHz.  No heater element installed.
Planning to use 1oz jam jars filled with my cleaning solutions: laboratory grade Petroleum Ether (Naptha), anhydrous 2-Propanol (IPA) and Hexane (for pallet fork and balance.)
Hello @JohnFrum,
May I use your consumables list in the Operating Manual that I'm developing please?
g.
Hello Everyone,
ULTRASONIC CLEANER SOLVENTS
Does anyone have any "recipes" for ultrasonic cleaning solvents?
So far, I have seen the following consumables mentioned:
...are there any more you recommend or steer away from?
For example, I saw mention of certain solvents potentially dissolving jewel mount shellac!  Wow, that would suck!
ULTRASONIC CLEANER APPLICATIONS
What about appropriate and inappropriate applications of ultrasonic cleaners?
1)  I notice on CHRONOGLIDE that it is strongly advised not to use ultrasonic cleaners on movements.
2)  I notice on RICHARD PERRIN that he routinely uses an ultrasonic cleaner on movements, including expensive ones.
Experts, what say you about this?
g.
Edited by Gramham
typo
g.
Ulatrasonics have been used for watch movement cleaning for more than 60 years. I have no idea why Chronoglide says not to use it. I know he shows the aluminum foil test at some point, where the US will perforate the foil if properly powerful- in 25 years of only using ultrasonic machines I have never seen damage and never heard of damage from the many watchmakers I know. The Watchmaster cleaning machines were only ultrasonic, no agitation, and my old Greiner Ultrason U2 is ultrasonic, no agitation, and uses isopropyl alcohol as the rinse for the water based cleaner that machine uses. Lititz Precision Products makes a professional modern version of the Watchmaster (their Matador machine) currently.
Isopropyl will dissolve shellac, in time. In a minute or two it won't. Water based cleaners will not rust steel parts (someone will say they do), as long as they are rinsed and dried correctly. Drying parts cleaned/rinsed in solvent based cleaner in room temperature air can easily cause rust, due to condensation on the parts as they cool from evaporation.
I did have a bad experience from a waterbased cleaner but that wasnt a professional product. I didnt know any bettet at the time and copied a youtuber's method, also maybe didnt dry quickly enough or throughly enough. Ive started to use a very small slow cooker to dry watch parts not inc. the pallet fork or balance wheel.  On low the temperature is around 60 degree Celsius. Also with  a little air from a puffer to disperse any excess rinse. It seems to work ok.
3 hours ago, JohnFrum said:
A couple of youtubers have recommended a food dehydrator for drying parts.
When I still used water as a rinse, this worked fantastic. I’ve got a dryer used for drying brass casings after cleaning them in a tumbler.
2 hours ago, dadistic said:
Hairdryer or heat gun. Just be careful.
Cheers!
I was always worried this would be either too hot or too much air pressure so never tried it myself.
Yep, please dont lol. Another bad experience 😪 for me. Although this was with a hairdryer trying to dry the case that still had the crystal and bezel on a diver. The crystal wasn't so much an issue as replacable the bezel insert was a different story. I will say i was over enthusiastic and also in a rush as i was going out. But besides my hard learned mistake the parts would need to be contained if using a hairdryer. A heatgun not sure what we talking about here, a paint stripper ? 🤔 i am thinking just a tad overkill lol. You can get mini heatguns that come as an addition on soldering stations for reworking joints, a safer downsized option to consider but still maybe overkill ?.  I would say gentle heat with gentle air circulation is all that is required. A speeded up rushed approach never ends well.
Cheers!
Definitely be careful 👍
I hold the basket with the parts in it in my hand. If the heat from the heat gun is cool enough for my hand, it's cool enough for the watch parts.
The heat gun I have was originally purchased years ago for shrinking balsa wood model airplane covering material, but I'm sure similar is available today. If you happen to have access to an industrial one, it would work,  just have to be carefull with the settings.  Not the soldering station kind, this kind, my setup is below too.
26 minutes ago, Gramham said:
Hello Everyone,
What about this?
? Its a warning not to use thin or fragile materials in the ultrasonic machine that this warning label is attached to. 🙂
Contained parts 👍. Is it a low wattage heatgun ?
Hello @Neverenoughwatches,
That warning does not appear in any labeling on my unit:
What I am attempting to do is write an English manual for my unit, seeing as the original manual is in Chinese.
Sorry for the confusion!
That said, ChronoGlide did say this to My Retro Watches in the discussion thread attached to his Ultrasonic Cleaner video:
g.
Edited by Gramham
Added photos
That warning does not appear in any labeling on my unit.  What I am attempting to do is write an English manual for my unit, seeing as the original manual is in Chinese.  Sorry for the confusion.
g.
Eyup G . I imagine the grey area lays somewhere between an expensive well known and well made brand and a cheap generic brand costing a tenth of the price. The sonic cleaner i have is similar to yours with a heater and 2 vibration settings which cost me about 50 gbp. Very cheap for an appliance known to do a good job of cleaning watch parts, this compared to a rotation wash costing thousands. What can we expect from it ? The one i have has not done any damage to movement parts as yet, that being said i always use the softer setting. The more aggressive setting is very obvious audibly.  I used to use the aggressive setting to clean the bracelets and cases until i noticed quite heavy pit marks around the back and lugs. The case may have had partial wear in these areas and the heavier setting dislodged or ate into the brass base metal ?. So some thought as to the durability of anything placed into the cleaner should be given. I wont be using the aggressive setting again unless I'm sure the item to be cleaned is  robust enough to withstand it, stainless steel i think would be fine.
If this isn't the ideal situation for a set of controlled experiments I don't know what else could be  🙂
I still have yet to set my unit up, and I don't know if it has a "gentle" mode or not.
When I have set my unit up (soon) and become more familiar with its full suite of operations (less soon) and have a means of measuring pitting (even less soon - I don't have a microscope [yet]) then OBVIOUSLY it would be interesting to run some experiments to see what the physical manifestations (if any) of cavitation on various types and thicknesses of metals would be.  The combinatorial potential of the variables is pretty big (duration, power, material, media).
On the face of it, however, I do agree with you.  As a "Rule of Thumb", it would be prudent to not put expensive, tiny, thin or fragile things in such a physically violent (on a microscopic level) environment.
g.
@nickelsilver- Thank you!
This is invaluable practice-based information for a nebie like me!  Wonderful!  Thanks once more.
...Chronoglide did retrospectively moderate his comments regarding ultrasonic cleaners and watch parts (somewhat):
g.
1 hour ago, Gramham said:
watches
Ahh G. You are talking my language matey. You cant beat a good experiment to discover for yourself exactly what is what 👍
combinatorial
Have you just made this word up ? I like it, do i have your permission to use it please ? 😆
Back peddling lol. Thats not like our Kalle !
If its big chunky and solid its fine, if its thin weedy and pathetic looking then its not. This is my very rough, vague and grey area rule of thumb. Lol. Yes i have sound logic and sometimes good advice, but I'm also an idiot and a nutter and have been awake all night and its now six oclock in the morning so i expect understanding and tolerance from everyone today 😀
Edited by Neverenoughwatches
If its big chunky and solid it fine, if its thin weedy and pathetic looking then its not. This is my very rough, vague and grey area rule of thumb. Lol. Yes i have sound login and sometimes good advice, but I'm also an idiot and a nutter and have been awake all night and its now six oclock in the morning so i expect understanding and tolerance from everyone today 😀
17 minutes ago, Neverenoughwatches said:
Lol thanks G. I wont be needing your permission to use it then ? 🙂
Hahahahaha - of course you have my permission to use any and all of my confabulated, archaic, obscure and otherwise (to me at least) neat-o terminology!
g.
Edited by Gramham
Typo
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
