Typically this thread is for showing one's achievements.  I marvel at the ability of some of those here, and hope to one day have the ability to do the same.  Well tonight I had an achievement, I lost 2 parts and broke another.  That's a personal best for me in one evening!
I was working on a cool little Seiko Lord Matic with a 5606A 25 jewel movement.  The scape wheel and 4th wheels both have capped jewels on the bridge.  While reassembling, I managed to lose both jewels.  Not at the same time mind you, no no...  I lost one, then miraculously found it, then lost it again when it sprung out of my tweezers after oiling, never to be found again.  The same thing happened to the other one about 30 minutes later after I gave up looking for the first jewel.  Now I'm down 2 jewels for the bridge.  Whatever, I decided to carry on, and managed to accidentally get my hairspring pinched beyond my ability to repair.  I decided to remove the hairspring and see if I could sort it out.  I've done 'minor' hairspring adjustments with decent success previously, so I thought I'd give this one a go.  After about another 30 minutes, it was worse off than when I started.
Sometimes you have one of those days where your hands don't do what your brain tells them to do!  Today was certainly one of those days for me.  I decided to put up my tools and just walk away for the night.  Thankfully I have a donor movement coming in a week or two.  When inspecting the watch upon disassembly I found some bent teeth on the barrel and 1 broken tooth on the 2nd wheel.  It looks like I'll have more parts to use off of that donor when it comes in.  I think I'll just put this Seiko LM in a drawer and leave it out of sight until the donor 5606A arrives.  Just the thought of it right now is aggravating!  This watch has potential.  It has a gorgeous green dial and a faceted crystal, and I'd really like to get it back up and running.  It has fought me every step of the way though.
LIke I said in the title, it is an achievement, but I'm certainly not happy about it!  Part of me just wants to go on ebay and find a couple of old Swiss manual watches with no complications and just work on those.  There'd be less stuff for me to screw up and I'd get a few 'wins' on the board.  I think I've just had bad luck on getting old watches in for repair.  I haven't had an easy one in a while (my definition of easy may vary greatly from others on here!).
Aw bless you Thor matey, you sound a lttle downbeat. Days like this make you appreciate good repair days even more . We all have had days like, I've had much worse from actualy stupidity, a nice watch that I'm still waiting to revisit almost a year later. Everytime i see the same watch on ebay and its finished selling price i relive my mistake, but you really have to laugh about it or you'll cry 🤣
Head up Thor we have all been there and some times it happens again, walk away have a coffee and sooth the nerves and pick it up in a day or so and it will be fine. when working with the likes of jewels and cap, springs try to cut down the eacapees by using Rodico or a sticky stick to pick them up. Not being under pressure if the fall off the stick they dont go far
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
