Hi, I need to get some new hands for an Elgin pocket watch, I was checking out the Cousins website and it needs the hole diameter, what is the easiest way of working this out? Should I use a micrometer to measure the diameter of the minute wheel where is fits? and the same for the hour on the centre wheel stalk?
Thanks in advance
also check out: https://pocketwatchdatabase.com/
tons of info on pocketwatches.
did you try looking on fleabay for hands? based on the size and serial number of the watch, they can be found there. or at least you could purchase an identical donor watch for parts and use the hands from it.
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
