hi guys
i need 2 links for a friends Planet Ocean the bracelet is a 1579/951 , now i have looked at Cousins site and using that bracelet number they come up with links 1581/953 . i just wondered if anyone could confirm these are the right links for the bracelet as obviously don't want to order them and find out they wrong as Cousins won't take them back as we know
thanks
Andy
hi guys
thanks
Andy
https://watchpart.co.uk/advanced_search_result.php?keywords=1579%2F951
Only ever ordered a stem from them but no problems.
Not sure why cousins lists differently though.
Spoke to Cousins today and they suggested putting in a non listed part request to verify it was the correct number , i did this and it came back with the 1581 part number as per the original search so it appears that they are one and the same , will know for sure tomorrow when they turn up.
thanks Andy
thanks Andy
Fingers crossed. Hope Cousins was cheaper too. I balked at £20 for a Seiko link [emoji33]
They were almost exactly the same price to be fair but i did put a bit of an order together so got some other stuff coming , it was meant to be here today as i paid for special delivery , not Cousins fault obviously but a bit annoying after waiting in all morning , now going to have to do the same again tomorrow.
Never mind didn't have anything better to do lol
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
