I'm currently looking at a French fob watch, and I've noticed what I can only describe as a 'cloudy' part of the crystal, as seen in the pic.
I've tried buffing this off with Windowlene, and then with (gasp!) acetone, but neither of these seems to have made an improvement.
This situation is new to me, I've not seen anything like this before. Am I in for a replacement crystal or how can I remove this, please? - I'm not really sure that this is something that is going to buff out as it doesn't exactly look like a a scratch and the area is not centred on the crystal?  ...
TIA
Ian
It almost looks like it has been stained. It depends how deep this is. Some on here have had success in polishing out scratches. However I am not a patient person so unless imperfections are minor I just change the crystal.
Hi There are propriatry  (polywatch)pastes for polishing watch crystals but I use Automotive chrome cleaner (Autosolvol) its mild enough and polishes ok takes a bit of elbo grease as does any polishing.
I use Simichrome which does a good job, just make sure the imperfection is on the outside, I spent ages the other day trying to polish out a blemish like yours only to find it was on the inside of the crystal, no idea how it got there though.
I use Abenaqui scouring paste (for kitchen cleaning) on a papertowel.  If it's a deep imperfection, a bit of very fine wet or dry paper speeds it all up.
Shane
Edited by Shane
If that is a glass crystal, then the crystal is probably "etched". A sticker or or something else that was slightly acidic was sitting against it for a long time, perhaps?
The way to get rid of that on a glass crystal is to polish with cerium oxide, I've seen a suggestion of using a piece of dowel rod to hold the cerium oxide paste (at the end). Supposedly makes it easier to handle than using a cloth.
Abenaqui scouring paste (I'm sure there is something similar in your location) uses feldspar which has a Mohs Hardness of 6 and works quite well on glass (if you are patient) and plastic crystals.  Glass has a Mohs Hardness number from 5.5 to 7, depending on the glass.  Cerium oxide was listed on the chart I found at 7, which will work faster but is more expensive and less available were I am.
I have used the piece of wood trick before but not on crystals (should still work).  The abrasive gets embedded into the wood and continues to cut rather than getting lost somewhere in the cloth.  Just make sure you average all of your polishing out across the crystal, otherwise you will see waviness through the glass.
Good luck.
Shane
I also use autosol. It was mentioned in a de carle book. I Have tried other things as well, bicarbonate powder not as effective  and also eucryl toothpowder which does actually work ok. But the Autosol is by far the best and is very comparable to polywatch, in fact i couldnt tell the difference.  I start with 600 grade wet and dry depending on how deep the scratches then 200 grit increments up to 2000 and then finish with Autosol. A crystal generally takes about 20 mins to half an hour depending how bad the scratches.
    • Sorry I have this thread forgotten. Now, why the stones break? Several reasons: One - the old stones are crunchy. Be careful! Two - wrong tweezers. Use brass ones. Three - wrong approach. The best way is not to grasp the stone close to working side. Grasp it for the middle part, the tweezers direction to be perpendicular to the stone. Use oscillating tilting movements when moving the stone.  Now several tips that are not read from the books, but found in my practice. They are good for my way of correcting pallet stones position: You don't need the heater for adjusting the stones position. The heater will be needed only to glue/fix the stone when the adjustment is already done.  The stone should seat tight enough in the slot without gluing. Tight enough so the movement will work normally and thus checking if the adjustment is correct is to be done before gluing. If the stone is loose in the slot, then heating and melting the shellac will make the stone move in by the capillary force. So, if the stone is loose in the slot, then find out if the stone is not correct or the slot is opened. If the slot is opened, then (in steel pallet forks) it is good idea to anneal locally only the small part that forms the slot before trying to close the slot. Also, put in the slot something slightly thinner than the pallet to limit the amount of bending If the stone must go out, the shellac can stay in place, it will not make the adjustment harder. Just bend the stone to break the bond between the shellac and stone. Then heating only will glue the stone again if the shellac is not old and degraded. If the stone must go in, then the shellac mus be removed from the slot bottom as to make space for the stone to go in. I often use pallet stones from USSR Slava alarm clock for pocket watches repair. Slava pallet stones are usually bigger (wider) than needed) and I grind/lap them to correct size for the slot. Grinding is of the side that never contacts the EW teeth. It is enough to put the stone on the lapping plate, pres on it with finger and move it forward/reverse several times while pressing, then check in the slot.
    • I used a small ultrasonic for years until it died, but it does need to be large enough to fit jars in to hold your parts, and small parts ideally are in mesh baskets within the jars so you are not fishing them out one by one with tweezers. So the one you linked might be too small and this kind of thing really the minimum workable size
    • You'll probably find when you get the dial it's slightly under the stated size to start with. Depending on the dial I'd mount it on a mandrel then spin it in a drill using a hard sanding pad to reduce the diameter.
    • Thank you @AndyGSi for the heads up. It is supposed to pressed down by a metal ring/bezel. I haven’t tried it yet. Let me check. Alternatively I may reduce the diameter of the dial, but I would need to mask/protect its face from dirt.
