watch glass cystal
hey guys.
been trying to remove a scratch from a watch glass. I used wet and dry that i had and the finest piece i had was 600. And the pic below show what i have ended up with. Is there anything i can do to save this glass? The glass cannot be replaced as no longer nade
cheers
gary
3M makes sheets that go all the way up to 2000 grit.
Is your crystal glass or plastic?
I would go increasing the paper grit from your 600, to 1000, 1500 then 2000. You don't have to but $25 at a time (you can probably get 3M wet-or-dry at your local hardware).
Then after you have the scratches out, polish with something like polywatch.
Have a read below. Hoowever, the crystal seem to be curved on an axis only, so it can be replaced with a blank or one of approximate size, then cut to measure.
Even 2000 paper still leaves an haze. One need diamond paste for a perfect job.
Polywatch and it's equivalent mildb brasive compounds do little or nothing to mineral glass. They are made for plastic crystals only.
Edited by jdm
You need to go much finer than 600 grit, I go do 1200 then finish with a polishing compound applied with a felt wheel on a Dremel type tool.
Standard Polywatch does not on glass, if it's glass, they do a glass version that is a diamond paste, diamond lapping paste could also be  used, but I found the wet and dry and polishing compound route worked fine for me
    • Bulova Accutron 2181 - had an open coil I managed to bring it back into life. Longines 9L - not serviced just pics   Eterna-Matic Centenaire "61" - 1438U - not serviced just pics. Longines Cal 431 - not serviced just pics Lemania Cal 4650 - not serviced, just pics.
    • attached is the tech /parts sheet. .   Can one ask how come it’s full of water. After being told that the waterproofing was not guaranteed.  Problem being electronics don’t mix especially withe the power source being attached.  You may be lucky but I should look out for a replacement movement or working donor to rob the movement from. C720.pdf
    • I thought this may be "right" forum to post this. After 7 months out in Switzerland I got my Navitimer back from Breitling. I had sent it off since its 20 years old to have a complete overhaul done... Nothing major wrong, but I did notice this seconds sundial skipping thingy.... $1300 later and 7 months later, I notice the 'skips' are still here unless the chronometer is engaged. I would think this is likely the hand binding up and maybe clearance with the dial, but at any rate Im interested as to whether this is something I should be returning the watch to Breitling for and insisting on being fixed. See below - 1 minute or so of regular running and then 1 minute with the chronograph engaged.
    • A friend of mine just gave me an old pocket watch. The case is in very bad condition but the movement itself seems to be in a quite good shape. I can't identify which movement is this, since I have to find a missing winding stem. I attach few photos in a case somebody would be able to give some hints.  Thank's folks
    • Hello everyone, I recently received a request for advice on purchasing a vintage watch, a Waltham A-11 ORD. DEPT. I asked if they were aware that these types of watches have radioactive hands and dials... but they had no idea what I was talking about. So, I thought of creating a video that could help recognize them, starting from the distinctive details to using a Geiger counter. I hope you like it and find it useful for those venturing into the world of vintage watches. Bye.
