57 minutes ago, RichardHarris123 said:
Got this as a sweetener on a job lot.  Nothing on the Internet about Oriso.  F in a shield under the dial, nothing under the balance. Doesn't run but the balance swings well when blown, hopefully just a service, it is filthy.
Oris used some silly variations of their name but this movement isn't anything like i have. They are always marked Oris and if a variation then OWC in a sheid the shape of a bat. Dial looks a bit pitted mate, do you think it will clean up ?
52 minutes ago, RichardHarris123 said:
I should of added the dial side photo. Says 294 but looks more like a 335 _ 8.
The train bridges and pallet cock is different rich but this may be a ranfft error or a 294 alteration at a later or earlier manufacture. The key less works are showing the same as yours a 294 or very similar. You are showing a broken yoke on yours. ☹
It does look very much like the 335 on the ranfft database. The dial plate is flatter on yours but everything else seems to match up. ?
Edited by Neverenoughwatches
Yes I've noticed the broken yoke.
Nice little movement
Morning mate. How you doin ? I couldnt quite match up as there seems to be differences on both calibres. The 335 does look to be the closest, although yours seems to have a flat dial plate where as the 335 has a bevel around  the edge. Strange ? Movement manufacturers eh 🤷‍♂️ never straight forward.  I hope you have some luck tracking down the yoke 🤞. I had a joblot of around 35 turn up yesterday morning, some real pigs among them by the look. I'm going to be very busy lol. And some toys coming tomorrow, its about time i got my finger out and did some repair 😂
Get some pictures posted. Good luck.  The 335 does look the closest.
I will do. At a brief glance some of them look like total shite. I did get a bit carried away on sunday night, i had money burning a hole in my pocket. I'm hoping the stock of around 1000 crystals some staffs and stems and the few vintage tools ive bought are a much better buy. 🤞
Where do I find parts sheets?
I usually look on the Documents Downloads in Cousins https://www.cousinsuk.com/document
or here https://watchguy.co.uk/cgi-bin/files
but there aren't and 29* or 33* movements listed.
The Swiss part number for the setting lever spring+bridge is 445
You can find them listed on ebay for the above movements.
Edited by mikepilk
I think i may have got just a little carried away. I did actually have about 25 of those already. Ive just had a good look through, there are about 10 that i havent  heard of.
Post them.  Carried away, I never do that,  Hehe. I have lots of old, ladies watches, tiny, no one wants them any more.
This is the worst of the bunch and about as basic as a mechanical watch can get.
Will i try to service and repair it ? Of course i will because thats what we do.
And this is probably the best.  A gorgeous Venus with beautiful lugs, i said LUGS. She had a few issues, one of which is a broken balance staff top pivot, which I'm hoping isnt going to be a bugger to find. Or will be setting me about learning to repivot. But she needs to be working, like all beautiful women. That sounded wrong but you know what i mean 🙃
Lovely watch, which calibre is it?
    • Good morning,   To be honest, I'm not sure I trust my own logic anymore 😅. But here's a picture of my own (failed!) attempt to install a new rotor axle. I punched way to hard and even split the metal of the rotor. My thinking was that, in my case, the axle sits "deeper" in the rotor and hence the rotor would be closer to the movement plates. Vice versa, I was thinking that a very light punch could cause the rotor to sit rather high. But not sure that makes sense because in both cases, the flat part of the axle and the rotor align equally.     Sorry, but is he saying that the outside of the caseback has been polished to such an extent that the inside of the caseback has deformed/sunk??? That sounds crazy to me because those casebacks are thick! Can you see any signs of that on the inside of the caseback? Have you tried screwing in the caseback a litte bit more or less so that the supposedly "sunk" part of the caseback would move from 9 o'clock to e.g. 6/7 or 11/12 o'clock?  If the caseback is truly deformed, maybe it could be punched/pressed back into shape (e.g. with glass/caseback closing press).      I agree with your choice. But yea, Rolex makes it VERY hard for independent watchmakers to do a perfect job because we can't get (original) parts easily.      Your pictures aren't too bad. But still impossible to see if the rotor isn't perfectly flat. You'd have to look at it with your loupe, from the side (like the pictures), and turn the rotor to see if the gaps (with the automatic bridge plates) increase/decrease.     Finally... how is the up/down play of the rotor? To test, take a toothpick/pegwood and press on the small triangular side of the rotor next to the axle (NOT the big side where the weight is. But the opposite side.). Does that lift up the weight-side of the rotor? There can be some play, but it should really be minimal. If there's too much play, a new spring clip is the first thing to do. After that, one could play around with the jewels. This is too much:
    • could start a new sub-brand: Bergeon-Pro Worked for Apple phones! Ah they already beat me to it:
    • Hello, those RR pocket watches are nice watches, there are still parts around...
    • The hairspring looks to be in good condition from the photographs, it is natural that the balance will perform slightly differently in different orientations. Assuming there is no damage, the difference may be caused by the balance moving relative to the jewels, not the hairspring itself. So too much space between the jewels (endshake) and the difference will be greater, if one jewel is oiled and the other not, then again a lower amplitude in one position than the other....and so on. If the difference is reasonable (like your 13 seconds) the the best thing to do is to make one position slightly fast (+7 seconds, and the other position slow -7 seconds) then this averaging of the error will make for a more accurate watch in use. If the difference was much greater eg 100 seconds, then you would need to troubleshoot the problem. Additionally, you need to let the watch run-in for 24-48 hours after a service to allow the new oils to work their way in to all the jewels and pivots etc before you make a 'real' timegrapher test, otherwise you can get strange results. For example the oil in the top shock setting may be evenly spread, but not (yet) in the bottom setting = high difference.... after 24 hours this oil will probably have sorted itself out and the difference may be much better.
    • Oy! No bad words in our forum please.
