EB8491 vs EB8420, 8420-73, 8420-74
Hello Black- and Locksmiths, Clock- and Watchmakers,
would anyone know if the EB8491 balance weel would be compatible with one of the 8420 variant?
8420 suffixes:
suffix -73: new balance, since 1973
suffix -74: set lever held by spring instead screw, since 1974
I downloaded the doc for 8423/8429 and the interchange parts docs from Cousins but I cant see how I compare the 8491 to the 8420? Would it be compatible with the -73/-74 version?
Thanks in advance and take care,
Lui
2845_EB 8423,8429.pdf 3764_EB Interchange Parts 199-301.pdf 3763_EB Interchange Parts 161-199.pdf
It seems they share both the same balance cock and the balance. I got some help from eBay. Now the next thing is to verify whats the difference between 8420 and 8420-73. I got both of them.
Parts list for 8491:
Balance cock: 121/3 Balance: 793
Edited by luiazazrambo
    • Hi @Roll1ex, welcome to WRT. Is there a big second hand watch market in Mumbai? I seem to see a lot of used watches and clocks on eBay coming from Mumbai.  I used to buy a watch every month from Mumbai on eBay. My mentor told me it was the best way to learn watch repair, by fixing everything that's not right.
    • Here is another option, if you have the patience to sort through the parts you usually find 50-100 screws as well as some other cool stuff. Most times I get an order from these guys I get a 250g box, takes a few days, but end up with hundreds of spares and all you need is for one of them to be useful and it pays for itself. Also helps hone your tweezer skills!
    • As Hector said they have too much  tension, that tension is also fixed and not easy to control. Conventional tweezers have infinitely variable grip provided by us.
    • Thank you and i appreciate that, it looks very different    Thank you sir but i think there is a little problem according to that reading it's because it is far different to the other move that i serviced, i will atouched the photo. They are different movements but this one is 7s26b movement and they are also different in shape when it comes to the ballance assmebly. Thanks also for the concerned i appreciate that.
    • Donor movement showed up, so I stole the bridge screw from it. Which made me sad, because it's in such nice shape! It seems a shame. Maybe I'll find a use for it one of these days. Unfortunately, the stem is for a different style of case and is much too short. Fortunately, I ordered a brand new stem from McCaw Company. Unfortunately, the crown on the donor movement is thoroughly stripped out (it unscrewed in a shower of brass) so i just put the old stem back in for now until I source a new crown. As you can see, it's just a little too long for this case. Overall I'm super pleased. I didn't think I'd like the bracelet, and even that is growing on me.   Anyone have a favorite crown assortment?
