Upside Down?
Solster
Hi All,
So things are progressing slowly but surely with my Smiths Enfield movement learnings! It's certainly a voyage of discovery. Thing is, I've somehow managed to get the half hour chime to strike on the hour and vice versa. No idea how I did it, but I can't work out how to get it back to how it should be.
Oldhippy, you kindly offered support, so can you or anyone else advise me on this please?
Thanks in advance.
John.
Sorry for the delay! Yep, here it is, but I have to say that it's not been dismantled (too much for me I fear), it's as it was when it was working okay! I've been mostly working my way through the mechanism seeing how each part interacts with the others. I seem to have somehow knocked it out of kilter and can't work out how to get it back! Hope you can see something.
Regards - John.
Hi John  whats th problem that you have with it at the moment, not rtunning , strike off,  chime off. If you could elaborate matbe we can point you in the right direction.  I have enclosed a picture of a front plate with all the terminology  and a picture of an enfield front plate for comparison
Hi, thanks for your reply watchweasol, and for the diagram - very helpful for me!
It's a bit strange (to me anyway) really, everything is working okay apart from the hour is chiming at the half hour setting and the half hour chimes on the hour? It was working the right way round before I started playing with it! Nothing has been dismantled. I've fiddled and tinkered with the different levers etc, but I just can't get it to go back to how it should be.
I'm thinking there must be a set of steps to follow to correct it, but I've tried turning back the time and holding the levers up, but all to no avail.
Any help and guidance appreciated.
Thanks - John
The movement you posted is not a chime, it's a strike. It should strike on the hour and it strikes 1 on the half hour. When it strikes on the hour, put the hour hand and minute hand on so the minute hand points to 12. When it strikes the half hour the minute hand will be pointing at six on the dial. Don't bother with the chime as its not the movement you have and it might confuse you.
Hi the sequence of events is, the center cam (two lobes) one for strike (longer) and the shorter one for the 1/2 hr.  as the cam turns the longer lobe lifts the long lever and puts the clock into warning (warning wheel rotates and locks) then as the cam rotates it drops the long lever and initiates the strike. The same sequence operates on the 1/2hr but the long lever is not lifted so high. warning then lock then release.  As Old Hippy said move the hands to initiate the strike (hour) take of the hands and re fit for the correct strike count. Now move the hands to the 1/2 hr position and it should strike the 1/2 hr then back to the hour and it should strike the hour.  as said this is a two train clock  one going and one strike.
Many thanks both, I've sussed it! I think you were telling me this, but it didn't register properly until the different sized lobes were mentioned - I simply took the minute hand off and repositioned it through 180 degrees. They are non-original hands that didn't come with the clock and I hadn't realised there was a right and wrong way to put the minute one on. Lesson learned!
Your guidance has been really helpful - thanks again.
John.
That is good news. Have a go at a few more striking clock movements that way you will build up your confidence if possible a slightly different movement a German one would be a recommendation from me  or a Smiths floating balance.  Good luck, we are always here to help.
Thanks oldhippy, I would likely go for similar Smiths one next I think as I'm starting to get to know them a bit now! However, as my source is charity shops and antique stalls etc it could end up being anything.
Just one more thing on the current project if I may - I've put the movement back in it's case now to see how it runs. It's not perfect, but getting there - but one thing that puzzles me is that both the hour and half hour chimes occur exactly one minute late. Is this normal or should it be bang on the hour/half hour? And if it needs adjusting how is that done?
Thanks - John.
Many of the minute hands on these clocks are fitted with a friction tight square center and they become loose, so the clock appears to strike slightly off the hour or half hour. There is a tool you can buy which is a waste of money. What I always did is use one of my square needle files and hold it in my bench vice so it points upward put the minute hand over the file and move it slightly to the correct passion. Be very careful not to bend the hand and check first that it is friction tight and not just a bent minute hand. When in the correct passion just give it a few taps with your bench hammer so it doesn’t move again.
    • If you are having counter tops ( i think thats the amercan term ) and some cupboards underneath where you dont require working legroom then that corner doesn't have to be a difficult access void. Lazy susans , we ( kitchen fitters ) call them cabinet carousels or you could just have two adjacent doors with a corner post fixed to one of them, though it does make for a long reach to get to the very corner. But a carousel is a good access solution, also there are sliding steel baskets available but these are bloody expensive and typically problematic, i really think they are a crap idea. What i like about fully fitted worktops, very tidy looking, no loss of space, and sidewards pinged parts are hopefully going to stay worktop side and not end up crunched on the floor.
    • Aren't corners of rooms a bugger though as it is really difficult to use the space underneath the intersection of the two benchtops. Lazy Susans are an idea I suppose. Somewhere to be able to put tools/soldering iron/testing machines that aren't needed on the bench top all the time. It is a bit tight in there, but at least I won't have to move great distances to get to another area. I need to get hold of another chair to have at the cleaning bench. I'll stand all the time at the lathe and I already have the stool for the workbench. Need to get the power sorted now and move the LED lights for over the workbench. There are four downlight in the ceiling that are currently halogen bulbs. Really quite bright so that's good. Ceiling fan as well. What else could one hope for?
    • So all that glitters is not gold when it comes to buying from ebay ( in fact very very rarely) i bought this as554 a few months ago. It was it's dial that attracted me to the joblot, which turned out to be printed on a postcard, that was the first red flag. During disassembly many faults were discovered as listed above,  but i was prepared to soldier on and see what i could achieve. I managed to make a setting lever for it which was a great learning experience and also correctly shape and de rust the hairspring.  Turning my attention to the balance assembly i have hit a road block. The staff broke when removing the roller but that wasn't so much of an issue as it was quite deformed anyway.  I also had several AS554 staffs that I could replace it with, problem is they dont measure up the same. I thought i had identified the movement correctly but what i think has happened is some heavy modification has taken place to make an incorrect staff fit. A nos staff is a slack fit on the balance wheel, the roller and the collet. The balance wheel has also been filed to within an inch of its life. I'm starting to doubt my identification of the movement either that or someone has converted the movement into a pure nugget of trash. Bit disappointed as i managed to get the train to spin lovely and put a good few hours into the setting lever. A balance complete might be the only option if one is available but you know when you are just wasting money. My thoughts are to make and modify something else to fit and work if that is possible, any ideas anyone ?
    • My second iteration. Cleaning to be underneath the towel rails. That makes sense. Moved the fridge and the maching/printing table around to the right. Changed the lathe to be used over the end of the bench. Not much room in front of the 3D printer, but you don't have to stand there while it is doing its thing. I may swap the fridge and the machining/printing bench yet. Not sure. And the 'doing' area. The power that was brought in for tha spa was 30A I think, so there will be more power than I need. I will have to check how level the benches are as well as find a spot for the movement testing rig to go. The tiles do have a fall toward the drain so I will have to work something out to be able to level the rig easily no matter where I put it. I'm also going to cut some slots in the bottom for pendulum clearance and some squares in the top section to be able to better see the movement. I'm getting more excited now.
