Letting down main spring?
How do I let down the main spring?
Do I remove the balance or barrel bridge first?
the first thing I would do is take the dial off. If you're lucky you will see the click on the other side. Then and it be nice if you give us pictures before you do this but I'll explain. With a key on the square although universal key would be better because it's around a no spin in your fingers carefully you might build two of the pin vice may be. Vacation one a hold on the square really nice and tight don't lose control the release they click carefully and you let the power off slowly.
Removing the balance bridge is also a good idea in that because the balance out of the way so you don't break anything. You do not want to remove the barrel bridge until the powers off the spring because when the power releases suddenly it tends to break things.
Thanks, I'll post pictures once the dial is removed.
one other little caution? Not so little if we get it wrong either. What kind of the escapement does this watch have? I'm reasonably sure it's a lever escapement but just in case it's not if you remove the balance wheel you won't have to let the power down because you'll spin down all by itself which may not be what you want to do. In other words of this was a verge watch you could remove the balance wheel and it would spin down you to temporarily block the train and then remove the balance wheel it be okay but if you don't know what you're doing and you pull the balance out the bump something when it's spinning that would be bad. But this just has the look of something later I don't even think it has a fusee even though it was originally set up for that or could have been set up for that. So just make sure that is a lever before you pull the balance of to avoid surprises
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
